Old June 28, 2008, 03:10 PM
Default First attempt at building a computer!
Sup guys. I found this site while going around for information on Direct Canada, and you folks look like a nice gang so I'll stick around.
And here is my first gaming build!
Case : Antec 900
Mobo : Asus P5E x38
CPU : Intel Core 2 Quad Q6600
PSU : PCP&C Silencer 750W Quad (red ftw!)
RAM : Corsair XMS2 TWIN2x4096-6400C5
Cards : 2xHIS Radeon HD 4850
HDD : Seagate Barracuda 7200.11 500GB OEM
CPU Fan : Zalman CNPS9500
I've got all the stuff already (save my mobo and fan...the wait is so cruel ), but anything you think I should have done differently?
Thanks!
Old June 28, 2008, 03:12 PM
Case : Antec 900
Mobo : Asus P5E x38
Thanks!
I'm not a fan of the 900 and prefer the 690 or 590.
I also don't like the red pc p&p cause you generally pay more for it being red.
Old June 28, 2008, 04:07 PM
Digitaldemon's Avatar
The 900 is actually a rather nice case with good air movement, as fpr the psu, the power n cooling guys make the finest psu's out there imo.
But grats and welcome to the community.
Old June 28, 2008, 06:37 PM
sswilson's Avatar
The only question I'd have is how much you intend to OC your rig?
For anybody OC'ing, I recommend at least DDR2 1000 as DDR2 800 can limit your FSB on an intel chipset board (can't run memory lower than 1:1 with FSB).
Old June 28, 2008, 06:40 PM
Well take into consideration most people are only going to be pushing at max a 450mhz fsb on their system which is just shy of 900mhz which ddr2-800 can easily do.
You really only need ddr2-1000 if you push 500mhz fsbs.
Old June 28, 2008, 06:55 PM
sswilson's Avatar
Depends on the DDR2 800. I've seen many "decent" sets which won't break 900.
IMO, I can see sticking with DDR2 800 if it's going to make a big difference in price, but if it's under $10/gig it's worth paying the bucks for a set that's guaranteed (assuming it's not U/S) to do 1000+.
Old June 28, 2008, 07:42 PM
Nothing record-breaking.
