Old June 27, 2008, 09:19 PM
Default First gaming build!
Well it's my first time building a computer and i've done a ton of research, but hey it's always smart to ask before you purchase ;) . Anyways, here are the components i've chosen. Are they all compatible...are they good choices? Should I change anything? I have a budget of around 900-1000 btw. Any input is greatly appreciated!
PS: http://www.ncix.com/products/index.php?sku=25984
Hard Drive: http://www.ncix.com/products/index.php?sku=25667
CPU: http://www.ncix.com/products/index.php?sku=29805
Memory: http://www.ncix.com/products/index.php?sku=24641
Mobo: http://www.ncix.com/products/index.php?sku...mp;promoid=1058
Video Card: http://www.ncix.com/products/index.php?sku=26780
Monitor: http://www.ncix.com/products/index.php?sku...mp;promoid=1058
Case: http://www.ncix.com/products/index.php?sku...nufacture=ANTEC
DVD writer: http://www.ncix.com/products/index.php?sku=24649
Old June 27, 2008, 09:23 PM
Power Supply? Check.
Hard Drive? Check.
CPU? Can you afford a 8400? Much better choice.
Memory? Bad choice. Opt for some Mushkin Redlines.
Motherboard? Check.
Video Card? Check.
Monitor? Upgrade to the 22" as with a 19" Widescreen you lose vertical desktop space.
Case? Switch out for the Coolermaster 590 or 690.
DVD Writer? Switch out for Pioneer DVR-212
Old June 27, 2008, 09:47 PM
JD JD is offline
I'd go with a P45 motherboard if I was in your position.
I like my Antec 900, but otherwise enaberif's advice is good. That memory is alright though, lots of people use it...
Old June 27, 2008, 09:50 PM
The crucial memory has problems with p35 boards so its a hit or miss.
Old June 27, 2008, 10:01 PM
PSU: http://www.ncix.com/products/index.p...0%26%20Cooling only $10 more and PC&C are TOP of the game
Hard Drive: Check
CPU: dont know much about the chip
Memory: Love my Crucial will take anything I throw at them and were recently involved in FSB world record....Double Check
Motherboard: my current reference is; AnandTech - Core 2 & AM2 Motherboards - Recommendations, P5K looks good
Video Card: 4850 are beating them and reviews just don't stop ravving about the ATI 48xx series;
http://www.ncix.com/products/index.p...acture=Diamond
Monitor: no idea but Samsung is Korean and imho expensive Chinese reproductions, consider Japanese or European Brands?
Case: Check 2 x 120mm inlet fans at front with filter looks good.
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
Old June 27, 2008, 10:57 PM
Moneyless's Avatar
IMO everything there looks good, but you should think about getting an aftermarket heatsink.
And TBH I think which case you pick is a matter of personal opinion since it will be the part you see the most.
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
Old June 28, 2008, 12:58 AM
Thanks for all the suggestions everyone =)
Yeah...i think ill go with the Intel Core 2 Duo E8400. Seems the memory isnt the best choice how about http://www.ncix.com/products/index.php?sku=18580
Oh and is the 4850 worth the extra money...is there a big difference between it and the 8800GT?
Old June 28, 2008, 05:11 AM
IMHO it would be worth it, just look at these links:
Overclockers Australia Forums - View Single Post - ATI Radeon HD 4000 Series | 4870X2 4870 4850 4600 | Reviews | Discussion | See OP!!
But I really want to emphasise the greatest upgrade I mentioned is that PC&C PSU, you look anywhere on the net and you should find they make the "BEST" PSU in the market, for an extra $10US you get a 750W Quad compared to a Coolermaster PSU (very average at best), too many under-estimate the importance of a good PSU and it can become the most significant component between a working system and a flop!!!!!! GET THE PC&C!!!!!!!
Please dont buy Corsair instead of Crucial, personally the are the best but you will find the are better than Corsair!!!!
Old June 28, 2008, 07:44 AM
Leclerc's Avatar
Ok for the E8400 ... run cooler and faster.
Ok for the corsair VX550W ... really good PSU, you don't need a 750W PSU and the corsair is using a 120mm low rev instead of 80mm high rev fan so it will run quieter.
For the video card, the HD4850 is a better choice than the 8800GT. It supports DX10.1, will outperform in most recent games, and if you get a Intel based mobo wich support Crossfire, you will have the option of upgrading for a low price in a year or two.
For the mobo, one of my friend had a lot of trouble with his Asus mobo and when you look on RMA stats, the P5K is not the most reliable of their products. Personnally, I've heard a lot of good things about intel chipset based Gigabyte mobos. They offer more or better functions for lowest price than Asus boards with comparable build quality and equivalent warranty (3 years). So if you want to eventually do crossfire, this one http://www.ncix.com/products/index.p...cture=Gigabyte could be a good choice, and if not, this one http://www.ncix.com/products/index.p...cture=Gigabyte or this one http://www.ncix.com/products/index.p...cture=Gigabyte could be good choices.
Don't forget to use the price match option of ncix to lower your prices. Take a look to Direct Canada to price match. Since it's a sister companie, thay usually accept all of them. You could also use the "price compare" link from this forum or use another website like www.shopbot.ca to find the better price in Canada to price match with.
Leclerc
AthlonX2 4600+ @ 3.0Ghz (tweaked by Ebdoradz) | Gigabyte MA790X-DS4 | 2x1GB Mushkin HP PC2-6400 @ 860Mhz | Silverstone Strider 500W PSU | Palit Radeon HD 3850 @ 720Mhz/1.76Ghz on 22" Acer X223w monitor | Thermaltake SopranoRS 101 | 1 x Seagate 250GB
Old June 28, 2008, 08:08 AM
sswilson's Avatar
The issue with crucial memory is a recent development which came about after they switched from double sided to single sided 1 gig sticks.
6 months ago I'd have been the first to recommend a set of Ballistix, now I'm telling folks to avoid them like the plague until crucial gets this worked out.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Monitor
