Old March 18, 2017, 02:39 PM
Talking Mini-ITX build advice - my first own build
Hello guys!
I've been investigating into making myself a mini-itx pc that i can bring around, as i might be moving to another country soon and i need the portability a LOT. first i looked into buying just a gaming laptop, but after seeing the crazy overpriced parts and machines, i couldnt bare to buy something that i knew was not worth.
These are 2 list i have made:
https://pcpartpicker.com/list/xpPHsJ - Alright, this one pcpartpicker detects some compatibility issues, but as seen in this video from techsource https://www.youtube.com/watch?v=Jz8jwjGavNo&t=145s the 2 parts that arent in pcpartpicker, are compatible. What do you guys think?
The second one has the same parts, but changing the CPU into https://www.amazon.com/dp/B01N0L41N7?psc=1 or https://www.amazon.com/dp/B01MZZJ1P0...ing=UTF8&psc=1. and keeping the same motherboard.
What do you guys think? As is my first build i want to be completely sure about the whole idea, so i dont spent this huge amount of money that i've saved (i work as a video editor with premiere and after effects). It'll be my first purcharse with my own earnt money as im 17th, and it has always been one of my dreams.
Please try to give me as much advice/recommendations as you guys can!
Old March 18, 2017, 02:40 PM
Also, my budget will be around 1100$ -1150$ so i still have some left to buy a keyboard, mouse and heaphones.
Old March 18, 2017, 03:07 PM
There are problems with your builds.
1. The first build is using a mATX board not an mITX.
2. I don't think mITX board for AM4 is out yet.
3. Intel CPU doesn't plug into a B350 board.
4. The compatibility issue warning is coming from the case that's too small for the board.
sswilson's Avatar
You have an mITX case and an mATX motherboard. They're not the same size format and are not compatible. I don't believe I've seen any mITX AM4 motherboards on the market yet.
edit: Ninja'd.......
Old March 18, 2017, 03:14 PM
It looks like BIOSTAR does have an ITX ready to go but it's BIOSTAR......
Gigabyte should have one coming out according to the Internet.
Old March 18, 2017, 03:22 PM
sswilson's Avatar
Not for everybody, but if you want portability but don't want to be tied to the mITX format (most mITX cases aren't really all that small, but the one you've chosen looks pretty good) you might consider an open test bench case that can be easily broken down for storage in a suitcase....
I've traveled for courses with a high speed tech station broken down and the rest of the bits in their original boxes, but they're a bit pricey... something like this is closer to your current budget...
https://www.newegg.com/Product/Produ...82E16811353001
edit: I've also used this particular test bench case and was pretty happy with it...
https://www.newegg.com/Product/Produ...-287-_-Product
Old March 18, 2017, 05:17 PM
MARSTG's Avatar
You could also use a mini system like a NUC https://www.newegg.ca/Product/Produc...82E16856158048
Old March 18, 2017, 07:17 PM
Bloodystumps's Avatar
Originally Posted by gabuti View Post
Hello guys!
all tho the NUC's are very impressive I don't think the GPU would be up to snuff for what the OP needs..
Tags
ddr4 3200mhz , gtx 1070 , intel , mini itx , ryzen
NAS build mini itx guilly Cases 10 November 8, 2015 05:13 AM
mini-itx build guilly New Builds 4 August 1, 2013 07:52 PM
My first build: Final revisions-Help&Advice (budget build) HigginsHere New Builds 4 October 9, 2012 07:56 AM
Advice please? Case for budget "mini" build draemn Cases 0 September 20, 2011 09:04 PM
Completed My Mini HTPC Build (bedroom PC) Mini box M350 CoolHandL Case Mods, Worklog & Gallery 4 April 26, 2010 07:25 PM
