<~----> How does this build look? - Hardware Canucks
Old May 25, 2008, 09:44 AM
Default How does this build look?
Sorry if it's the wrong forum, but I didn't see one that was leaps better. Pretty much decided on this setup, but what do you all think?
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
Mobo: ASUS Striker II Formula LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard
GPU: 2 x MSI NX8800GT 512M OC GeForce 8800 GT 512MB
PSU: CORSAIR CMPSU-620HX 620W
CPU: Intel Core 2 Duo E8400 Wolfdale 3.0GHz
Memory: CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
HDD: 2 x Seagate Barracuda ES.2 ST3250310NS 250GB 7200 RPM (in raid 0)
Heatsink: XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
Mostly I am concerned about the motherboard. I want something that can handle the DDR2 1066 memory, but I have heard mixed reviews about the asus board. The XFX MB-N780-ISH9 LGA 775 NVIDIA nForce 780i SLI Intel Motherboard says it can do up to 1200 with EPP 1.0, and I have no idea what that means. :) The EVGA board, which seems to be the highest rated, does not support DDR2 800. Can I live without it? I have been told that only having 800 memory reduces your FSB to the same speed. If this is not true it would actually solve the problem and I would just get the nvidia board.
If I do end up just going with ddr2 800 memory:
Newegg.com - OCZ Reaper HPC Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Desktop Memory
or
Newegg.com - CORSAIR XMS2 DHX 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Desktop Memory
Think that's everything of note. Gonna use the DVD burner from my current PC. Thanks for any advice.
Last edited by DarkDisciple; May 25, 2008 at 10:12 AM. Reason: XFX MB-N780-ISH9 LGA 775 NVIDIA nForce 780i SLI Intel Motherboard - Retail
Old May 25, 2008, 10:47 AM
Jack Rabbit's Avatar
With the way RAM is shaping up now getting 800MHz is starting your 1/4 mile 20 feet behind everyone else. What does all this total up to? Looks like you want a really nice system so I would not scrimp on the RAM.
- James Graham
Old May 25, 2008, 10:53 AM
belgolas's Avatar
About ram you wont notice a difference in gaming with a 800mhz or 1066mhz. You might get 1-2 extra fps.
It looks like you are building a very nice rig.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old May 25, 2008, 10:57 AM
Ah cool. I wasn't too hot on the asus motherboard, and the XFX one looked kinda shady with the "Memory Standard: DDR2 800 (up to DDR2 1200 with EPP 1.0)". I will probably just spend 100 bucks less and get the evga board with ddr2 800 memory.
-Thanks!
Old May 25, 2008, 11:47 AM
CanadaRox's Avatar
-Thanks!
They will both run with DDR2-800, ad JEDEC specs (5-5-5-18 2T 1.8v). EPP is just some useless gimmick that nVidia made that will automatically apply the tighter timings the RAM is rated at. All it does is saves you 5 seconds of changing the ram timings (which likely will be changed around if your overclocking anyways).
So just go with whatever motherboard is cheaper. Any RAM should work, you will just have to manually set the timings if its not EPP (which usually makes the RAM cost more, so you don't want it).
Project: Black and White
Old May 25, 2008, 11:06 PM
Of the 2 DDR2-800 kits I would get the Corsair DHX. NCIX has them for a lower price I think...and they also have the new G.Skill PI series DDR2-1000 for ~$115 IIRC...so check them out.
Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust
Corsair HX520
Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB
Intel C2D E6300 @ 3.5ghz 1.45V
Arctic Cooling Freezer 7 Pro
Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V
eVGA 7600GT KO @ 630/880
Seagate 7200.10 320GB
Samsung SH-162
Samsung 205BW
Logitech Media Keyboard
Logitech MX518
Old May 26, 2008, 10:33 AM
kruzn4evr's Avatar
The EVGA 780i mobo is worth the money for it's lifetime warranty alone, the ASUS board is 3yrs I believe, I know several people who have had the ASUS and had nothing but headaches especially when it comes to service. The E8400 you can't go wrong with, great for OC'ing, check ncix.com for prices, it's $198 I believe.
Sounds like a nice build to me.
Old May 26, 2008, 10:35 AM
Change your case from the 900 to the Coolermaster 590 or 690 you'll be much happier.
I wouldn't really worry much about SLI and go for a single powerful card.
