Old May 4, 2016, 03:54 PM
Default 1x 200mm / 2x 140mm / 2x 120mm at the Front?
Hi,
I have a Phanteks Mini ITX, see the photo attached.
What is the best configuration to have the best airflow possible?.
  • 200mm (Phanteks fan (PH-F200SP), came with the case)
Fan Size 200 x 200 x 30mm
Noise (dBA) 25 dBA
Airflow (CFM) 110.1 CFM
Static Pressure (mm/H2O) 1.04 mm/H2O
850 rpm
  • 2x 140mm (Corsair AF140 Quiet Edition)
Fan Size 140mm x 25mm
Noise (dBA) 24 dBA
Airflow (CFM) 67.8 CFM
Static Pressure (mm/H2O) 0.84 mm/H2O
1150 rpm
  • 2x 120mm PWM (Corsair SP120 PWM)
Fan Size 120mm x 25mm
Noise (dBA) 35 dBA
Airflow (CFM) 62.74 CFM
Static Pressure (mm/H2O) 3.1 mm/H20
2350 RPM
Note: I have one AF140mm at the rear.
So, what do you think, which will be the best option?.
Old May 4, 2016, 03:56 PM
Do you care about noise levels?
Old May 4, 2016, 04:02 PM
yes, i would like a quiet fan too
Old May 4, 2016, 08:17 PM
Bond007's Avatar
From what I have read the AF aren't as good as the SP when there is restriction (like the case panel/filter/etc). For that reason I would stick with SP if you do elect to swap the fan. Personally I would probably stick with the 200mm though, unless it's not running well.
Old May 4, 2016, 10:07 PM
I'd also keep the 200mm fan- the company put it there for a reason. ;) My case came with three 230mm fans, which are quiet and move a lot of air; resulting in lower temps compared to online results for Asus boards with a 6700k. I am currently setting up fan curves.
As to other options, what about Noctua fans? I still use one AF120* fan in my case (external GPU exhaust) and, at full speed, it's LOUD.
* 120mmx25mm, 63.47 cfm, 1650 rpm, 30 dBA and 1.1mmH20
Old May 4, 2016, 11:54 PM
Bond007's Avatar
From my playing with some 120mm fans I find 1000-1200rpm (depending on the fan) audible but not overly intrusive, and 800rpm seems to be where you start getting silent.
Old May 14, 2016, 11:24 AM
I would leave it as is. Linus tech tips did a video on fans and found that case fans did not make that huge of a difference.
Do i need 2 fans at the top? 120mm or 140mm? RodoGodo19 New Builds 9 March 13, 2016 10:37 PM
[FS] WC for sale: 120mm & 200mm rads, GT AP-45s, Fan Controller, and Tank Res mojojj Buy/Sell & Trade 21 March 10, 2014 08:26 AM
[FS] GTX560Ti 448, 120mm radiator, 120mm/200mm fans... WTB/T: Modular PSU, i5 2500k bundle wonton1017 Buy/Sell & Trade 2 June 18, 2012 05:13 PM
[FS] 120mm Fans ::: WTT: A 140mm fan ::: jcmaz Buy/Sell & Trade 21 April 14, 2012 10:06 AM
120mm vs 140mm Brian@NCIX Air Cooling 12 February 22, 2011 02:27 PM
