Old April 28, 2016, 01:32 PM
Cool water cooling
Hie first time on here.................
I have a question about a build I am planning to start this winter.
NEVER built a computer before and I am going to build a water cooled system.
I have heard that you have to change the water every year depends on the liqued used.
BUT on YouTube I watched someone build an oil cooled pc in a fish tank and they said that the mineral oil should be OK for many years as long as you didn't get bits in it to short out the electrics.
So can you uses mineral oil instead of water??
Old April 28, 2016, 01:46 PM
sswilson's Avatar
AFAIK not inside your tubing. I'd think that mineral oil would be thicker than water and as such would put a heavy stress on any pump you choose to use.
As far as swapping out the water goes.... I'd almost be willing to bet that you'll end up redoing your loop at least once in your first year.... :) Other than that, all I ever used was low mineral content distilled water with a couple of drops worth of PT Nuke to keep possible algae away.
Probably more likely to have issues with the tubing leaching crap than with the water.
Old April 28, 2016, 01:55 PM
SugarJ's Avatar
If you've never built a PC before I'd recommend you start with a All-In-One watercooler like the Corsair H110. Custom loops can be tricky. Get your PC built and working, then add a custom loop if you feel the need.
Old April 28, 2016, 03:58 PM
KaptCrunch's Avatar
silver fittings FTW and distilled
Old April 29, 2016, 01:25 AM
thanks for the help
*** HELP water cooling with generic water block romanm Water Cooling 9 March 17, 2014 04:02 PM
Can't decide! Case, Water Cooling/air cooling Birk Cases 2 September 11, 2013 07:44 PM
Aquarium gear for water cooling??? WATER CHILLER??? clshades Water Cooling 6 March 15, 2012 09:21 PM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
