Old April 15, 2016, 03:48 PM
Default Compatibility between Phanteks Mini ITX case, h100i V2 and Corsair Dominator Platinum
Hi,
Components:
  • Phanteks Mini ITX case
  • Asus Z170 Pro Gaming
  • Corsair Dominator Platinum
  • Corsair H100i V2 with fans installed
I have Vengeance LPX which is Low Profile, but the Dominator Platinum is taller. Will I have any issues with these things?
The Radiator with the fans installed will fit perfectly inside the case using those memories?
Will I have issues using Dominator Platinum, with that case using the radiator with fans installed?.
Old April 15, 2016, 05:13 PM
sweenytodd's Avatar
You'll be good with the LPX ram.
The forum reviewed the case here: Phanteks EVOLV ITX Review - EVGA 980 Hybrid + Corsair H105 (Watercooled Build)
Old April 15, 2016, 05:50 PM
but i want dominator platinum, it will fit? or not?.
Overclocking Corsair Dominator Platinum CdnGhost RAM 3 March 4, 2014 09:54 PM
[FS] !! SOLD !! DDR3 Corsair Dominator Platinum 2133Mhz Alpine Buy/Sell & Trade 5 April 25, 2013 04:58 PM
Corsair H100i mini review stoanee Member Reviews 13 November 20, 2012 07:52 AM
Corsair Releases ‘Dominator’ Platinum DDR3 Memory Sam_Reynolds Press Releases & Tech News 4 June 25, 2012 01:56 PM
