Old April 15, 2016, 08:22 AM
Default H100i v2, SP120 PWM or 3-pin?
Hi,
I want to buy the Corsair Hydro Series H100i v2, but I don't like the fans that came with it.
Should I buy:
  1. Corsair SP120 Quiet Edition PWM
  2. Corsair SP120 Quiet Edition non-PWM (3-pin)
What is the best configuration for this case?.
Old April 15, 2016, 09:13 AM
sswilson's Avatar
Assuming you're using the incorporated fan controller you should be looking for a 4 pin replacement.
Hydro Series H80i/H100i SP120L 2700 RPM Replacement PWM Fan
http://www.hardwarecanucks.com/forum...-review-2.html (shows controller fan splitter).
According to a Corsair employee (on Reddit I believe) the V2 is simply a rebranding of the 100i GTX so you can get your info on the unit by checking out reviews on the GTX.
Old April 15, 2016, 09:43 AM
For AIO coolers stick with PWM fans so that it can adjust to the temps as required.
Corsair H100i kruzn4evr Price Check 0 January 15, 2015 12:06 PM
980X OC and H100i rjbarker Overclocking, Tweaking and Benchmarking 10 May 8, 2013 10:52 AM
Silverstone TJ09 & H100i rjbarker Cases 0 March 26, 2013 07:14 PM
No bios no nothing after H100i install Jeff1961 Water Cooling 23 March 3, 2013 06:28 AM
Corsair H100i mini review stoanee Member Reviews 13 November 20, 2012 07:52 AM
