Old April 9, 2016, 09:18 AM
Default Need help on new build
I'm attempting to install a to a Corsair Hydro H80i GT to a ASUS Maximus VIII Impact motherboard. The H80i requires me to connect a mini USB 2.0 cable (picture below) to the USB 2.0 connection on the motherboard for the Corsair link support which control fan and pump (I think) speed. Issue is I can't seem to find an spot to connect it on this motherboard (doesn't seem to mention one in the manual. Only free pins I can find is squared in this picture below, which I also can't seem to find out what they are used for, no info in the manual or online. I know this cable is optional, but I feel like it would be nice to have. What would be your advice? Thanks
Old April 9, 2016, 09:46 AM
sswilson's Avatar
https://www.asus.com/ca-en/Motherboa...S-VIII-IMPACT/
It doesn't look that the board has any 2.0 usb headers on it. I'm not sure if they make 3.0 to 2.0 header adapters so your only choice might be to route a USB cable from the corsair unit to a rear motherboard USB port.
I did this with my setup for a while and can confirm that just a straight cable (with the appropriate connector for your corsair on one end) run off of a rear USB port works fine.
Old April 9, 2016, 10:05 AM
Cool, I'll take a look around for adapters. If not, I'll most likely just leave the cable out of the build for now. Any idea what those pins in the picture are for?
Old April 9, 2016, 10:18 AM
sweenytodd's Avatar
Those 4 pins has no function stated in the manual. You might want to call Asus for that.
First pc build, part list opinions and questions for 1440p gaming build jerryaire New Builds 3 October 15, 2015 08:44 AM
WIP My EK Corsair 750d build-log ***first watercooled build*** ASUSg4mer Case Mods, Worklog & Gallery 29 May 10, 2015 07:39 AM
My first build: Final revisions-Help&Advice (budget build) HigginsHere New Builds 4 October 9, 2012 07:56 AM
Wanting to build a Home File Server, thoughts on this build? Silver_40 New Builds 4 September 19, 2012 10:36 PM
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
