Old January 17, 2016, 10:44 AM
Default X99 build suggestions
Hey all,
Last build was 10yrs ago. time to upgrade. Primary use of this new rig is for photo/video editing, video rendering/conversion, and slight gaming.
So far these are the parts that ive already purchased:
CPU: i7 5280k
Motherboard: Asus x99m-WS
Case: Phanteks Enthoo Evolv mATX
Need your help on the following:
RAM
AIO Watercooler (planning to OC)
PSU
GPU
M.2/SSD/HHD (boot, project files, archive)
Budget left: $1000 USD
Old January 17, 2016, 12:33 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Memory: There are some really good quad channel 32GB kits on sale right now. For example this G.Skill @ $149: G.SKILL Ripjaws 4 Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 2400 (PC4 19200) Desktop Memory Model F4-2400C15Q-32GRR - Newegg.com
Next up the AIO. I'm going to suggest the Corsair H80i GT. At $78 after rebate....killer deal: Corsair Hydro Series™ H80i GT High Performance Water / Liquid CPU Cooler. 120mm - Newegg.com
GPU. Gigabyte GTX 980 Windforce at $479: GIGABYTE GeForce GTX 980 DirectX 12 GV-N980WF3OC-4GD (rev. 1.0/1.1) 4GB 256-Bit GDDR5 PCI Express 3.0 SLI Support WINDFORCE 3X GAMING Graphics Card - Newegg.com
PSU time! Corsair AX760. 80+ Platinum at just $115 after rebates.....yes please! CORSAIR AX series AX760 760W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS PLATINUM Certified Full Modular Active PFC Power Supply New 4th Gen CPU Certified Haswell Ready - Newegg.com
The storage system will be interesting. With $120 left, there aren't many choices but the Crucial BX200 480GB would be my suggestion: Crucial BX200 2.5" 480GB SATA III Internal Solid State Drive (SSD) CT480BX200SSD1 - Newegg.com
Hope that helps!
Old January 17, 2016, 12:40 PM
KaptCrunch's Avatar
M2 go with Samsung 950 Pro SSD comes in 256 or 512Gb, bios see's it and windows
Notice: if your going to have multiple GPU's you will loose a PCI-e slot to M2 also your limit to your 28 lane CPU means single GPU support. the 40 lane would best suited for your video stuff
Old January 18, 2016, 02:55 PM
definitely go with samsung pro 950 if you can afford it
Old January 21, 2016, 02:55 AM
This is my Photoshop computer configeration
Photoshop is RAM and CPU intensive but usually 16 GB sufficient
the next bottleneck is the video card Check your memory interface 256 Bit and a good memory bandwith - spend your money on the card not extra RAM
Putting the OS and applications on a fast SSD and there is no delay reading an writing large files. Long term storage a RAID 1 with two harddrives
My proposed rig will be quiet
CPU
[IMG]file:///C:\DOCUME~1\John\LOCALS~1\Temp\msohtml1\01\clip_im age001.gif[/IMG]
Intel Core i7-5820K 3.3GHz 6-Core Processor
CPU Cooler
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard
Asus X99-DELUXE ATX LGA2011-3 Motherboard
Memory
GeIL 16GB (4 x 4GB) DDR4-3000 Memory
Storage
Samsung 950 PRO 512GB M.2-2280 Solid State Drive
Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive
Video Card
NVIDIA Quadro M4000 8GB Video Card
Case
be quiet! SILENT BASE 600 w/Window (Black) ATX Mid Tower Case
Power Supply
be quiet! DARK POWER PRO 11 850W 80+ Platinum Certified Semi-Modular ATX Power Supply
Operating System
Microsoft Windows 10 Pro OEM (64-bit)
Case Fan
be quiet! SilentWings 2 50.5 CFM 120mm Fan
Old January 21, 2016, 08:41 AM
Fudd Rucker's Avatar
Why are gaming cards being discussed with a photoshop production machine? Get a firepro or quadro card. They are perfectly fine for light gaming. While the "gaming" cards are shit for production.
The build above is pretty solid for that, although I think the firepro cards are a bit cheaper. Personally id go with a xeon and ecc.. but hey overclocking a production machine is what we should be doing now right?
I couldnt think of something snarky or interesting to put here this time around.
Old January 22, 2016, 12:57 PM
Thanks all for the great input! Motherboard arrived yesterday.
I was looking at 32Gb DDR @ 2400mhz for RAM. Is that sufficient enough or should i consider a faster speed?
@victormolyneaux whats your workflow for storing media? Im thinking of using the m.2 for boot and apps, a 120gb SSD for project files (.prproj, .psd), cache files, and my lightroom catalog. Then install 2x240GB SSD in Raid 0 for exports. Or should i just install 1x4TB HD (mechanical) for exports/archives? One more thing as far as SSD's brands Samsung EVO or OCZ Vector 180?
Graphic cards I'm still on the fence with. A quadro would be nice as my friend is rocking a K5200, but can't afford that right now. What do you guys think of the FireproW7100?
Old January 22, 2016, 06:45 PM
MARSTG's Avatar
The workspace could be done with 2 hdds in raid 0 while the final product should rest on a raid 1 array. Wd blue hdds could be involved, no need for black.
Old January 23, 2016, 10:37 AM
Here's my parts page on pcpartpicker:
Intel Core i7-5820K, Phanteks Enthoo EVOLV - System Build - PCPartPicker
I might have gone overboard on the PSU. Whats the ideal wattage for this system with room for upgrades?
Old January 24, 2016, 04:44 PM
just pulled the plug on a GTX TITAN. Found a good deal i could not pass on amazon. I did get it used, however the seller has 100% rating with the option to return. Let see what happens.
I'll post pics as soon as it arrives.
First pc build, part list opinions and questions for 1440p gaming build jerryaire New Builds 3 October 15, 2015 08:44 AM
WIP My EK Corsair 750d build-log ***first watercooled build*** ASUSg4mer Case Mods, Worklog & Gallery 29 May 10, 2015 07:39 AM
My first build: Final revisions-Help&Advice (budget build) HigginsHere New Builds 4 October 9, 2012 07:56 AM
Wanting to build a Home File Server, thoughts on this build? Silver_40 New Builds 4 September 19, 2012 10:36 PM
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
