  #21 (permalink)
Old February 8, 2016, 10:47 AM
having a hard time finding the X2 Prestige is stock at a decent price. Might have to settle for something else. X61 Kraken or the h110i GTX...
  #22 (permalink)
Old April 3, 2016, 07:23 PM
Default UPDATE
System is up and running! so i ended up with the Kraken X61 and and the Zotac 980ti Extreme Amp edition. CPU running at 4.5ghz w/ 1.2V Loving it so far!
now im about to pull the trigger for a WD 5TB Black on newegg for an archive drive. they're running a special for $189 right now.
What would you guys suggests for backup system? NAS? RAID? Cloud?
Thanks
  #23 (permalink)
Old April 4, 2016, 05:46 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
"What would you guys suggests for backup system? NAS? RAID? Cloud?"
Short answer: Yes. As in all of them. BUT none of those options are true backup storage options. They are all online storage or nearline storage options.... none are offline backup. The simple rule is: if its online its going to fail.
Depending on how serious you take your data you may want to do this:
RAID for redundancy in your system -> Online 'backup'.
NAS for further redundancy (as RAID can and will fail... and you can just copy the data back after it fails) -> nearline 'backup'
Portable HDDs (two per data. eg need 2TB of backup? get TWO 2TB drives) that is offline AND offsite (say in a lockbox at your bank) with a backup of the data.... as NAS arrays also fails.... or if your house burns down / floods/ etc and kills your NAS and RAID arrays. You can sub in a tape but meh.
That is a backup scheme. Basically defense in depth is the name of the game if you want to backup your data.
Do most need this level of backup... nope? But I would recommend a NAS and a portable drive as min level for 'backing up' important data.
First pc build, part list opinions and questions for 1440p gaming build jerryaire New Builds 3 October 15, 2015 08:44 AM
WIP My EK Corsair 750d build-log ***first watercooled build*** ASUSg4mer Case Mods, Worklog & Gallery 29 May 10, 2015 07:39 AM
My first build: Final revisions-Help&Advice (budget build) HigginsHere New Builds 4 October 9, 2012 07:56 AM
Wanting to build a Home File Server, thoughts on this build? Silver_40 New Builds 4 September 19, 2012 10:36 PM
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
