  #21 (permalink)
Old June 18, 2014, 09:53 PM
rjbarker's Avatar
Thought ypu maybe interested-----this is a build I did in the same Black Pearl Case for my Son in Law awhile ago...:
X58 EATX Classified Evga Mobo
980X
12GB 1600 Mhz Triple Channel RAM
No problem putting in a H100i Closed Loop Cooler...performs very nice, may even be able to put another set of Fans there for "push / pull' if you got a little creative with the EPS12v along the top edge.....mild OC on the 980X @ 4.1 Ghz
SLi 650Ti Boost Cards
If I remember correctly the bottom will take a large PSU as in a AX 1.2 kW no problem (I think as I was discussing SLi 680's at the time and I'm a fan of the 1.2kW ;) You can see there is a ton of room in the bottom of the Case !!!!
If your planning any type of Watercooling in the future I would go with something that can accommodate at minimum a 120.3 Rad up top ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
  #22 (permalink)
Old June 18, 2014, 11:29 PM
That is a very nice build sir!
I might not be able to have the PSU fan facing down as you have, as the bottom fan location is apparently limited to 170mm...
The closed loop water cooler on the CPU looks great! I was thinking of going with an air cooler till I'm ready to overclock but you might have changed my mind. :)
Could you elaborate on what you meant by an extra set of fans for push/pull? The radiator of your cooler doesn't seem to leave much room for additional fans at the top.
Frugalmeister
EDIT: Regarding the PSU, I see that there is definitely room for a larger model. It's just that there is a solid metal "separator" in the way that I'm worried would prevent airflow to the PSU if the fan is facing down.
  #23 (permalink)
Old June 19, 2014, 02:13 AM
Originally Posted by Bond007 View Post
The gains definitely drop after 1866mhz. If you do want to stay with red here are some options for a bit more money (all <$180) @ 2133mhz:
Corsair Vengeance Pro CMY16GX3M2A2133C11R 16GB 2X8GB DDR3-2133 CL11-11-11-27 1.5V Red Memory Kit - DirectCanada
Thanks for the suggestions Bond007. That Corsair set at DirectCanada is extremely cheap compared to other sites. Before I decide to order though, one question:
The ASUS Maximus VII Hero has the following specification in regards to memory:
3200(OC)/3100(OC)/3000(OC)/2933(OC)/2800(OC)/2666(OC)/2600(OC)/2500(OC)/2400(OC)/2200(OC)/2133(OC)/2000(OC)/1866(OC)/1800(OC)/1600/1333
What does the above actually mean, the fact that only 1600 and 1333 are allowed without overclock? Shouldn't I save some money and get a 1,600 MHz pair I can overclock myself? I'm now wondering if anything higher than 1,600 is just a very expensive, factory-overclocked 1,600.
Frugalmeister
  #24 (permalink)
Old June 19, 2014, 02:47 AM
Dzzope's Avatar
Originally Posted by Frugalmeister View Post
I just got my video card! But I'm wondering if it's actually new... The box was sort of open and I see that the opening of the tinted plastic bag it's in is only sealed with a piece of tape. Shouldn't it be heat-sealed all across? :/
Frugalmeister
EDIT: I just watched an unboxing video. The box was supposed to be wrapped in plastic, and it wasn't. The flap wasn't even in its place. What should I do, if anything, before proceeding?
I would contact the seller and start complaining. You pay for new you get new, you pay for open box you get open box. Generally the static bags are not heat-sealed, they are usually folded with some sticky anti-static bag like tape holding it closed.
Though this varies on manufacturer and product.
For memory speeds, Basically you need to mess with some settings in the bios to get them to run at the higher speeds. The frequency that is on the ram is the rating which they are made to work at and should be tested as such, slower ram may clock but your playing the silicon lottery for a couple of bucks.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
  #25 (permalink)
Old June 19, 2014, 03:38 AM
Thank you! I'll write to them once my order from yesterday has been shipped. Don't want my complaining to affect that in any way. :)
Ok, I'll spend a few more bucks. :)
Frugalmeister
  #26 (permalink)
Old June 19, 2014, 03:49 AM
RAM and Windows ordered!
Frugalmeister
  #27 (permalink)
Old June 21, 2014, 08:31 AM
Bond007's Avatar
Some potential power supplies:
http://www.ncix.com/detail/corsair-r...89918-1215.htm
Or if you really don't mind overkill (because this would be truely overkill):
http://www.hardwarecanucks.com/forum...-mobo-ram.html
1300w EVGA PSU for less than what you will find a 1000w for new. Its very well reviewed:
EVGA Supernova G2 1300W Review
As mentioned, the default max speed for ram is 1600mhz. Anything above that is technically an OC (even if its made to operate at those speeds). You have to go into bios to go above. Usually you just have to select the XMP profile in the bios to get to the rated speeds.
  #28 (permalink)
Old June 21, 2014, 10:41 AM
Thanks Bond007, but I've already ordered everything save the CPU and a cooler for it. I went with the EVGA Supernove 1000G2. :)
I'm thinking of going with the Intel i7-4790K when it's (hopefully) released next week. Could someone suggest a cooler that goes with my black-red themed case and components? I am open to either air or water cooling, but I do want to keep things as cool and quiet as possible as I plan to overclock.
Thank you!
Frugalmeister
  #29 (permalink)
Old June 21, 2014, 11:25 AM
I have come across the Phanteks PH-TC14PE, which is looking very nice. It is only a tad louder than the Noctua NH-D14 but I'm willing to trade that for a colour scheme that goes with my case. :) Cooling should be just as good.
What do you guys think? Anything more suitable out there?
Frugalmeister
EDIT: Actually, this might not fit my case, motherboard and RAM. I'll have to really look into this before buying.
  #30 (permalink)
Old June 21, 2014, 12:39 PM
Bond007's Avatar
For a cooler I am not sure there is much out there that offer colors for matching. I know good air coolers like the one you posted get great temps for the noise, but personally I am a fan of the bang for buck offered by <$40 air coolers. If you want to invest more than that I would go to an AIO water cooler. Then you have no worries about stress on the motherboard from the CPU cooler weight, or running into issues with RAM.
Ah...I missed that you ordered a PSU. The supernova PSUs seem to be getting very good reviews (the other EVGA ones are more average).
Gaming... Laptop? Ew? Bear with me, life advice needed! D4ng3r New Builds 5 April 4, 2012 12:20 PM
New-ish build specific advice needed! fearm3now New Builds 2 February 9, 2012 03:34 PM
Build advice needed jevehn HTPC Systems & Software 1 June 16, 2010 04:53 AM
New gaming rig advice needed! Massacah New Builds 18 March 30, 2010 10:33 PM
New Build Advice Needed (mobo + hd + cpu for under $250???) cb2222 New Builds 7 January 12, 2010 06:23 PM
