Old January 30, 2014, 06:19 AM
I wouldn't do it with that powersupply. Low tier thermaltake power supplies have never been known to be good.
Old January 30, 2014, 07:10 AM
b1lk1's Avatar
Nvidia cards have to match, exact same GPU, you have to get another Ti. Brand does not matter and it will default to the lowest memory size/gpu speed card so that would be good to match as well.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old January 30, 2014, 07:50 AM
supaflyx3's Avatar
Unfortunately your motherboard doesn't support SLI.
Old January 30, 2014, 02:19 PM
How does it now support it. I have three graphics card slots?
Old January 30, 2014, 02:30 PM
great_big_abyss's Avatar
The chipset is not capable of supporting SLI. It will support Crossfire, but NOT SLI. In otherwords, it won't transfer the information SLI uses through the PCI bus.
cross border lcd/led tv shopping mo' power Display Units 12 November 29, 2013 10:57 AM
Cross province movers moocow Off Topic 10 June 7, 2012 12:39 AM
'Cross-Canada' Moving Advice Arinoth Off Topic 20 July 6, 2010 01:09 PM
new to cross fire have a question or two Shadowmeph Video Cards 1 May 5, 2010 10:58 AM
