-   -   Parts Advice needed (http://www.hardwarecanucks.com/forum/new-builds/63891-parts-advice-needed.html)
Trotts November 1, 2013 04:25 PM
Parts Advice needed
-Mainly gaming, but some video editing
-Around $1500 including Taxes and shipping
- U.S.
4. IF YOU have a brand preference.
-Not a fanboy, but I do prefer Intel. Will use AMD if it is the best option.
- monitor, keyboard+mouse, speakers,
-I have read around and think I have an idea for a decent build'
-default speed to start, but will overclock as/if needed
-I have a EVGA GTX 780 classified and plan to get the other parts over the next month.
9. What resolution and settings do you use?
-Right now I use 1920X1080 resolution and try to get settings to max. I will be getting a new monitor with in the next year.
10. Are there any specific technologies you want?
-The latest and greatest support
This is what I have come up with so far. Intel Core i7-4770K, Corsair 750D - Intel1 - ....'s Saved Part List - PCPartPicker Anything you can think of better, price/performance wise, would be appreciated. I have also been looking at the
Corsair Carbide Series Air 540 case, but am not sure about a vertically mounted DVD burner. Does anyone have experience with those?
Pabz0r545 November 1, 2013 06:00 PM
Looks like some solid picks. You could probably shave off some money by going down to a 750w or 850w power supply which would be more than enough even for sli 780's.
Also personally not a big fan of ASUS. I feel as though they are overpriced. Can get the same features/quality for a better price. I would recommend one of these 2 boards. Should have just as many features and possibly more.
MSI Z87 Mpower ATX LGA1150 Z87 3PCI-E16 4PCI-E1 CrossFireX/SLI SATA3 HDMI USB3.0 Motherboard
MSI Z87-GD65 Gaming ATX LGA1150 Z87 3PCI-E16 4PCI-E1 CrossFireX/SLI SATA3 4K HDMI USB3.0MOTHERBOARD
Google ASUS motherboard RMA in USA. Thousands of horror stories from their USA motherboard RMA department.
Dzzope November 1, 2013 07:29 PM
If you do go Asus, look at the maximus VI Hero.. awesome board. Otherwise it's a very very good build if overkill for 1080.
Trotts November 1, 2013 08:00 PM
Yes, that PSU is more that needed, but with the rebates and stuff it has right now, it's cheaper than most 850W PSU's. And I probably will, at some point, buy another 780 and SLI.
The Hero is another one I am looking at and like a lot, and I will be getting a new monitor within the year and up my resolution.
Trotts November 4, 2013 01:37 AM
OK, I have a few of the parts ordered, but I still can't decide on a case. I have been looking at the Corsair 750D and Air 540 because I really like their design and look. Boxish and plain with a big side window and not like it was designed by the Aerospace Industry. And i like that they have room to mount a radiator on the front or top in push/pull. But the reviews I have read are like a mixed bag of good and bad. Like the 540s front panel wiring may be too short to reach my motherboard, and that is a hassle I would like to avoid.
So, any suggestion on some good cases like the two I mentioned, with good air flow, would be greatly appreciated.
Shadowarez November 4, 2013 04:53 AM
Have you looked into the Haf stacker 915f picking one up for a server box I'm making after my Ivy-E 4960x build.
