  #71 (permalink)
Old August 31, 2015, 09:40 PM
Shadowarez's Avatar
Bought time to refresh build with some new parts.
1.980Ti
2.Intel 910(thanks to WolfBane)
3.Swiftech H240x (thanks to cascades for screws needed)
Soon as parts come in I'll update thread again new pics and benchmarks.
  #72 (permalink)
Old September 1, 2015, 04:51 AM
WolfBane's Avatar
wheres therm pics man :)
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
  #73 (permalink)
Old September 1, 2015, 05:27 AM
Shadowarez's Avatar
Haha those have to be added when I do this right. I'll add em and good thing is winters coming and my rig is by a winow I can open just enough so Rad at top will pull in -45c -55c air. Now I just gota find a way to isolate airflow to just that area and mother nature will be cooling my rig to very good Temps ;)
  #74 (permalink)
Old September 1, 2015, 08:56 PM
WolfBane's Avatar
sounds a bit damp to be pulling in such cold air into a warm case , wouldn't things start to sweat ?
I USE EMT ONLY
  #75 (permalink)
Old September 1, 2015, 11:40 PM
Shadowarez's Avatar
Did it last winter surprisingly none if parts were hot enough to sweat I had cpu down to 9c under load lol. I gota mod something to funnel cold air into rig while not dropping room temp to 5c.
  #76 (permalink)
Old September 2, 2015, 03:17 AM
fishingfanatic's Avatar
Smile New Builds
Get some electrolytic grease and apply a thin layer to the wc components to prevent condensation.
Wrap the lines if possible with plumbing insulation.
That foam is easy to cut and handle. In this case my biggest concern would be possible condensation frying something.
Yeah with my setup I found the gpu didn't like going much lower than 4-5 C, and the cpu 8-9 C for me anyway.
Close the heat vent and block the bottom of the door if you can isolate the room. It will also help .
GL dude !!!
  #77 (permalink)
Old September 2, 2015, 04:09 AM
Shadowarez's Avatar
Yeah I'll have to try a few things but if I can make it work basically colder it gets outside cooler cpu gpu will run lol.
Intel i7-4960X Ivy Bridge-E Review Comment Thread SKYMTL CPU's and Motherboards 42 September 7, 2013 03:39 PM
Socket 2011 n Ivy Bridge E 4930k / 4960X rjbarker Rumor Mill 20 May 11, 2013 05:25 PM
Wanting to build a Home File Server, thoughts on this build? Silver_40 New Builds 4 September 19, 2012 10:36 PM
Anybody know of a beastly worktop? jibz Mobile Computing 11 September 11, 2011 07:49 PM
