  #31 (permalink)
Old October 6, 2013, 01:31 AM
Shadowarez's Avatar
In 10 seconds of searching xoxide found my answer lol found a y splitter for pwm fans that takes 1 3 pin converts it to 3 and a internet enabled fan controller from bit Felix so I can monitor my temps via my cell.
  #32 (permalink)
Old October 6, 2013, 07:56 AM
Lamptron | Powered by InnovationLamptron | Powered by Innovation
I really like the manual dial type fan controllers. I've had issues with the software type controllers in the past with the shitty software. That's not to say all the software style controllers suck.
Mah Rig now
Mah Rig before
My stuff for sale.
  #33 (permalink)
Old October 6, 2013, 10:22 AM
rjbarker's Avatar
Lamptron FC9....4 Channel 50W per channel.
I'm not into monitoring my temps with software nor do I need PWM controlled fans.
The FC9 Lamptron has robust sliding knobs.....very smooth and effective.
During normal day to day stuff all fans run at about 50% (very quiet), only running LinX for stability testing high OC's do I push the fans to around 80% and monitor Core Temp on my desktop.
This is the Lamptron FC9 I decided to gowith...no whistles n bells....just a solid robust Voltage Control Controller. The LED's do brighten / dim as knobs are adjusted for fan speed. Numerous color LED's are selected by using a "jumper"...
Lamptron FC9 5.25in Bay 4 Channel 50 Watts Per Channel Fan Controller 7 Colors LED - Black
Firestrike Extreme: 21.452
MARK 11: 32.530
  #34 (permalink)
Old October 10, 2013, 07:41 PM
Shadowarez's Avatar
Nice I'll put the order in for it along with the Evo ssd and the Sammy 840 Pros. Any have any luck finding a Asus Raidr Exspress in Canada?
  #35 (permalink)
Old October 16, 2013, 12:25 PM
if you haven't decided on a cooler, i'd say stay away from h100i
I own one since april and kind of regret it. you might find it more trouble than it's worth, unless you got lucky and got it to work right away.
a top end air cooler should do as well and run quieter with same or cheaper price.
i am planning to switch back to air with either dark rock pro 2 or noctua d14
The only benefit is the h100i uses less case space, if its radiator/fans fit in your case that is.
  #36 (permalink)
Old October 16, 2013, 02:39 PM
Dzzope's Avatar
Got a 110 myself and had absolutely no issues.. But yes, be sure it fits first, just like anything.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
  #37 (permalink)
Old October 16, 2013, 09:10 PM
rjbarker's Avatar
Whats your issue...NO dont go go back to Air vs Liquid due to this poster...I've purchased tons of HW and the H100i worked great out of the box...no issues....just didnt cool enough compared to my H320 for higher OC's!!!
Please guys, if you have negative experiences with HW be detailed when posting your problems!!!
MARK 11: 32.530
  #38 (permalink)
Old October 18, 2013, 11:36 PM
Shadowarez's Avatar
I'm still buying the one recommended but I'm also buying a high-end air cooler incase this watercooler pump breaks or something goes wrong and I gota rma the cooler.
  #39 (permalink)
Old October 27, 2013, 10:00 PM
Shadowarez's Avatar
Good news the Holy Grail of Motherboards is up for pre-order on ncix the Rive Black Edition got mine reserved now gota wait for the Asus Raidr to come to Canada in early November. November is going to a Expensive month for me lol. Rive Be / ps4 / Asus Raidr/ R9 290x Crossfire.
  #40 (permalink)
Old October 28, 2013, 12:20 AM
Dzzope's Avatar
More money than sense... and 290x "crosswords"???
Random quotes:
Intel i7-4960X Ivy Bridge-E Review Comment Thread SKYMTL CPU's and Motherboards 42 September 7, 2013 03:39 PM
Socket 2011 n Ivy Bridge E 4930k / 4960X rjbarker Rumor Mill 20 May 11, 2013 05:25 PM
Wanting to build a Home File Server, thoughts on this build? Silver_40 New Builds 4 September 19, 2012 10:36 PM
Anybody know of a beastly worktop? jibz Mobile Computing 11 September 11, 2011 07:49 PM
