  #21 (permalink)
Old October 5, 2013, 10:15 AM
rjbarker's Avatar
Although the Swiftech H320 is an AIO Cooler, unlike the H100i it IS customizable, and comes with Barb fittings and filling port on the Rad, you could indeed add a Reservoir or add in Mobo Block if you like.
Swiftech recommends changing out the water every few yrs as well as ensuring the Loop is kept "topped". I installed the Rad at the top of my 900D in a manner so the full port is easily accessible by removing the top dust screen.
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
  #22 (permalink)
Old October 5, 2013, 12:29 PM
I suggest to get the swiftech.
  #23 (permalink)
Old October 5, 2013, 12:53 PM
rjbarker's Avatar
Just another note, you do know you're going to be paying a premium for the extra 3 MB L3 Cache with the Extreme Chip....from what I've been seeing the Extreme Edition Chip OC's no better than the K Edition Chip. I picked up an Extreme Chip for X58 build yrs ago, BUT back then the Extreme Edition Chip had unlocked Multiplier and easier to push higher OC's.....somewhat justified when OC'ing.
Think you may have mentioned you already had the Chip,,,disregard if thats the case for sure ;)
Timespy: 18.613K
MARK 11: 40.185K
  #24 (permalink)
Old October 5, 2013, 07:38 PM
Shadowarez's Avatar
I'll fix my rig Sig with parts I already have lol. And I think your right Id rather get swiftech now then changing diff aio coolers later I seen in a vid the guy used gentle typhoons as fans are they better suited for rads?
  #25 (permalink)
Old October 5, 2013, 07:44 PM
rjbarker's Avatar
Never used em before, understand they have models with higher static pressure (better for Rads), lots if folks including myself have gone with Noctua NF either F or P series.
Timespy: 18.613K
MARK 11: 40.185K
  #26 (permalink)
Old October 5, 2013, 08:57 PM
Shadowarez's Avatar
Yeah was looking at picking up 6 Noctuna 120mm and a few 140s if I can fit em in.
Want enough cfm flowing to keep everything cool. also any ideas on what a good vrm coolers.
  #27 (permalink)
Old October 5, 2013, 09:50 PM
rjbarker's Avatar
I haven't noticed any CPU Throttling (indication of Overheating VRM), so I haven't concerned myself with any Aftermarket Cooling, with that said another plus for having your top fans as intake, as I said earlier keeps air moving over the Motherboard.
Timespy: 18.613K
MARK 11: 40.185K
  #28 (permalink)
Old October 5, 2013, 11:12 PM
Shadowarez's Avatar
When it comes to setting up I'll ask how to setup a push pull config. My last rig was a Q6600 lol. All I did was find a pure copper cooler and alot of high cfm fans.
  #29 (permalink)
Old October 5, 2013, 11:35 PM
rjbarker's Avatar
Under Case Mods Gallery section look for my Thread Corsair 900D, some pics there showing the H320 with Noctua push/pull config.
http://www.hardwarecanucks.com/forum...tech-h320.html
Timespy: 18.613K
MARK 11: 40.185K
  #30 (permalink)
Old October 6, 2013, 12:54 AM
Shadowarez's Avatar
What Fan Controller would you recommend to keep all these fans together.
Intel i7-4960X Ivy Bridge-E Review Comment Thread SKYMTL CPU's and Motherboards 42 September 7, 2013 03:39 PM
Socket 2011 n Ivy Bridge E 4930k / 4960X rjbarker Rumor Mill 20 May 11, 2013 05:25 PM
Wanting to build a Home File Server, thoughts on this build? Silver_40 New Builds 4 September 19, 2012 10:36 PM
Anybody know of a beastly worktop? jibz Mobile Computing 11 September 11, 2011 07:49 PM
