Old September 12, 2013, 10:36 AM
Default Need suggestions for Power Supply.
Hi professionals~
I have
Asus Sabertooth Z87
GTX 780
3T HDD& 250G SSD
my case is Corsair HAF X
My current power supply is HX 850
I am going to get a second GTX780 for SLI, do I need to upgrade my power supply? If so, which one should I get? Anything else I need to upgrade for 780sli?
Thank you so much for your time!
Old September 12, 2013, 10:55 AM
SugarJ's Avatar
I'd think you're good with your HX850. In SKYMTL's test system with a 6-core SB-E CPU and mobo, the stock 780 draws 406 watts. EVGA GeForce GTX 780 ACX SC Review
Your 4-core Haswell CPU should draw quite a bit less, and unless you're running 2x highly overclocked 780 Classifieds I think you have plenty of power head room.
Old September 13, 2013, 08:17 AM
FreeKnight's Avatar
You should be fine. I've got an OC'd 1366 920, 24GN RAM, 3 HDDs, 2SSDs and two SLI'd GTX 780 ACXs and I'm fine still.
Edit: With that same PSU, sorry meant to say that at the start
Old September 13, 2013, 08:28 AM
Bond007's Avatar
I think you will be ok as well.
Power supply surges detected during the previous power on. Asus Anti-Surge was trigge Varroa Power Supplies 7 December 18, 2012 06:50 AM
OCZ Technology Unveils the PC Power & Cooling Silencer Mk III Power Supply Series Sam_Reynolds Press Releases & Tech News 8 November 9, 2011 08:48 PM
PC Power & Cooling Unveils New 760W Silencer Power Supply FiXT Press Releases & Tech News 3 December 18, 2010 04:53 PM
