Old August 11, 2013, 12:14 AM
Default Need suggestions for CPU liquid cooling.
i7-4770k
Sabertooth Z87 motherboard
budget $100 $20more or less
any suggestions? is Corsair H50 a good choice?
Thanks guys
Old August 11, 2013, 12:31 AM
IRQ Conflict's Avatar
No, H100i. If your willing to spend a little more than get the NZXT Kraken X60.
Old August 11, 2013, 12:32 AM
Caldezar's Avatar
My understanding is that the 4770k runs very hot. So you're likely going to want something with some meat on it. But it really depends on your case as to what you'll have room for. Are you planning to overclock?
Unless you're looking used, I don't think you'll get an h50 anywhere. Look in to the H80i, but consider 3rd party fans. The H100i will be out of your budget.
Old August 11, 2013, 12:34 AM
KaptCrunch's Avatar
echo 100i room for future add-on's
No it won't. Kraken X60.
Old August 11, 2013, 12:55 AM
What about a Swiftech H220? You may not be able to get it in the US.
Old August 11, 2013, 04:22 AM
Thought id jump in here guys! building a PC setup for my boss, 4770k but stuck between h100i or x60. Additionally, I'm not sure if the x60 will fit inside an R4 (read lots of different opinions online). Lastly, I Havent built a computer in a year and stayed out of the world (compared on how i used to be). Is the 4770k a good chip? Heard lots of problems overclocking??? Boss cant afford a 3930k though.
Old August 12, 2013, 03:28 PM
Ultima_weaponx's Avatar
I know you said liquid cooling, but I whole heartily recommend an air cooler like the Noctua NH-U14S for your budget.
It will cool as good as an H100 (even at load to my knowledge) and be even quieter.
Consider it! Even if it looks ugly!
It's keeping my 3770k happy as a clam!
Best Liquid Cooling For COSMOS II CHICKEN_jr Water Cooling 2 April 3, 2012 08:33 AM
TEC liquid cooling. Overclocker~4.1 Water Cooling 14 September 24, 2009 07:16 PM
Self contained Liquid cooling Gtx 285/95's Technokat Video Cards 5 August 6, 2009 02:58 PM
Dry Ice and Liquid Cooling? CanadaRox Water Cooling 13 December 27, 2008 08:27 AM
WTB: Liquid cooling system for CPU pat767 Buy/Sell & Trade 3 January 30, 2008 10:03 PM
