-   -   Need Build Reccomendations (http://www.hardwarecanucks.com/forum/new-builds/61711-need-build-reccomendations.html)
BrokenHalo83 June 16, 2013 12:14 PM
Looking to upgrade, but haven't been really keeping up with hardware for some time now. Looking to build something that will do for the next 3 years or so
What I currently have:
Phenom II 955
Asus M4A785TDM-EVO
4GB Mushkin Ram
ATI 6870
Coolermaster Silent Pro 850w
Not interested in E-ATX cases at all either. I currently have one. Too big. Don't like it
I do all my gaming at 1920x1080 as well
1. What YOUR PC will be used for.
Games, Pro Tools, and Adobe Creative Suite
2. What YOUR budget is
12-1500ish
Canada, most likely NCIX
4.IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
ATI Video Cards/ Everything else is wide open
Monitor,mouse and keyboard as well as soundcard
Not in quite some time
Mild OC at most.
Next 3 months
LHN91 June 16, 2013 03:37 PM
One quick question - which is higher on your priority list, gaming, or Adobe CS?
Dzzope June 16, 2013 04:07 PM
Next 3 months
Come back a week or so before you want to build.
fishingfanatic June 16, 2013 06:45 PM
New Build
Too many variables with that much time.
I 2nd coming back approx. a wk b4.
FF
:biggrin:
Bond007 June 17, 2013 12:36 PM
likely going to be an i7/2x8gb ram based build. Details will need to be sorted pending pricing when you build.
