Old June 12, 2013, 03:49 AM
Default hackintosh build (3monitors?)
Hello,
i want a hackintosh with 3monitors if possible. can someone pls confirm if the below will be ok to work together for a hackintosh build?
4. BitFenix Prodigy Arctic White
PRICE 90USD
Amazon.com: BitFenix Prodigy Arctic White: Computers & Accessories
5. Seagate Barracuda 1 TB 7200RPM SATA 32 MB Cache 3.5-Inch Bare Drive - ST31000524AS
PRICE 79USD
Amazon.com: Seagate Barracuda 1 TB 7200RPM SATA 32 MB Cache 3.5-Inch Bare Drive - ST31000524AS: Electronics
6. SanDisk Extreme SSD 240 GB SATA 6.0 Gb-s 2.5-Inch Solid State Drive SDSSDX-240G-G25
PRICE 120USD
Amazon.com: SanDisk Extreme SSD 240 GB SATA 6.0 Gb-s 2.5-Inch Solid State Drive SDSSDX-240G-G25: Computers & Accessories
7. Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CML16GX3M2A1600C10)
PRICE 120USD
Amazon.com: Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CML16GX3M2A1600C10): Computers & Accessories
8. Gigabyte Intel Z77 Dual Thunderbolt ATX Motherboard with BT4.0/Wi-Fi (GA-Z77X-UP5-TH)
PRICE 225USD
Amazon.com: Gigabyte Intel Z77 Dual Thunderbolt ATX Motherboard with BT4.0/Wi-Fi (GA-Z77X-UP5-TH): Computers & Accessories
9. Intel Core i7-3770K Quad-Core Processor 3.5 GHz 8 MB Cache LGA 1155 - BX80637I73770K
PRICE 314
Amazon.com: Intel Core i7-3770K Quad-Core Processor 3.5 GHz 8 MB Cache LGA 1155 - BX80637I73770K: Computers & Accessories
10. Corsair Enthusiast Series CP-9020039-NA650W ATX12V v2.31 / EPS12V 80 PLUS BRONZE Certified Modular High Performance Power Supply
PRICE 105USD Amazon.com: Corsair Enthusiast Series CP-9020039-NA650W ATX12V v2.31 / EPS12V 80 PLUS BRONZE Certified Modular High Performance Power Supply: Electronics
NOTE------- IS THE POWER SUPPLY OK?
11. EVGA GeForce GTX680 SC SIGNATURE 2048 MB GDDR5 DVI DVI-D HDMI DisplayPort 4-Way SLI Ready Graphics Card, 02G-P4-2683-KR
PRICE 497USD
Amazon.com: EVGA GeForce GTX680 SC SIGNATURE 2048 MB GDDR5 DVI DVI-D HDMI DisplayPort 4-Way SLI Ready Graphics Card, 02G-P4-2683-KR: Computers & Accessories
OR
12. EVGA GeForce GTX670 FTW 2048MB GDDR5 256bit, Dual Dual-Link DVI, HDMI, DisplayPort, 4-Way SLI Ready Graphics Card Graphics Cards 02G-P4-2678-KR
PRICE 378USD
Amazon.com: EVGA GeForce GTX670 FTW 2048MB GDDR5 256bit, Dual Dual-Link DVI, HDMI, DisplayPort, 4-Way SLI Ready Graphics Card Graphics Cards 02G-P4-2678-KR: Electronics
13. Thermaltake Slim X3 Low Profile 36mm Height CPU Cooler CLP0534
PRICE 23USD
Amazon.com: Thermaltake Slim X3 Low Profile 36mm Height CPU Cooler CLP0534: Electronics
IS POWER SUPPLY ENOUGH??
DO I NEED EXTRA FANS FOR THE CASE?
WILL EVERYTHING FIT IN THE CASE (i love this case) ?
OTHER CPU COOLER?
will it support 2-3 MONITORS
CAN I EXPAND LATER ON WITH 2X GFX CARDS?
thank you
Old June 12, 2013, 12:29 PM
Go to Tonymacx86 instead for hackintosh help. But basically with an Nvidia card and their native driver, 3 monitors should work or at least that's the impression I'm getting after a quick search. Do not just buy random parts and hope it will work. See their buyer's guide and it's will more or less work out of the box. The motherboard is listed as working but Thunderbolt, BT, wifi doesn't work. It seem that Thunderbolt only works as a display for onboard graphics but nothing else at this moment. The BT/wifi card onboard is simply not supported. So I suggest you move to something cheaper and simpler for your motherboard. If you do need a wifi card, just go with AR9280 or AR9380 ones because they are just plug and play. I just order a AR9380 and it works.
GTX 670 - 3 Monitors
tonymacx86 - Building a CustoMac: Buyer's Guide May 2013
Nvidia SLI in a Hackintosh?
Success with Z77 Thunderbolt Motherboards
Old June 12, 2013, 12:46 PM
Dzzope's Avatar
try pcpartpicker and price-match it somewhere to save some. Also I can't advise going Seagate for HDD unless it's some odd requirement.
650 is plenty for 1 card, possibly will want a lil bit more for 2 cards.. it'll probably run but I wouldn't like to see the heat and stress it would put a 650W bronze psu under.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old June 13, 2013, 12:52 PM
hero1's Avatar
Your motherboard will not fit in that case. You need a mITX board or get an ATX case.
Tags
hackintosh , mac os x , triple monitor
Hackintosh + Gaming PC = 1200USD amogh13 New Builds 6 July 30, 2011 07:47 AM
Hackintosh build Prolab New Builds 7 March 14, 2011 12:15 PM
Cheap Hackintosh Full Speed New Builds 15 June 29, 2010 01:15 AM
Nvidia and ATI in same rig (Hackintosh) Grey13 New Builds 12 May 24, 2010 07:53 AM
Completed Project: Power Hackintosh Photograph Case Mods, Worklog & Gallery 107 May 21, 2010 08:03 AM
