Old May 30, 2013, 05:49 AM
DAMN! to use 6gb you must have a sh1t ton of pages opened :D
Old May 30, 2013, 10:07 AM
Dzzope's Avatar
Usually 8 -15. Min is 6, with ts, skype, Steam, origin, possibly utorrent, sticky notes, some gadgets and the whatever game.
Granted I could cut much of that down. But this is the way I like using my pc. Whats the point in spending what we do if you can't.
Old May 31, 2013, 12:19 PM
hero1's Avatar
I would keep everything but why not wait and get the 4770K, ROG board, GTX 780, 16 GB RAM (I have it and it is useful when you have a lot of things going in the background and gaming at the same time), and the money you save from not buying GTX 690 you can get yourself the Crucial M500 900GB SSD. Dun dun!
Old June 1, 2013, 10:13 AM
Dzzope's Avatar
To the OP, get back to us with your current spec and what you intend to do with the rig and what resolution you will play at (and if it's 60hz or 120hz)
Till then there is no point in saying anything.
Old June 1, 2013, 10:15 AM
Nobody uses 6gb of ram in any system unless your encoding or virtualizing. Windows caches any unused memory which looks like your using it but your not.
SATA-IO Releases Revision 3.1 Specification SKYMTL Press Releases & Tech News 0 July 19, 2011 01:45 PM
IEEE Ratifies 802.11n Wireless LAN Specification FiXT Press Releases & Tech News 4 September 14, 2009 01:35 PM
Are my temps fine? arekieh CPU's and Motherboards 2 November 23, 2008 09:38 PM
USB 3.0 specification being hijacked? Hardware Canucks Press Releases & Tech News 0 May 13, 2008 11:32 AM
