-   -   Bitfenix Prodigy Living Room Gaming Build Help (http://www.hardwarecanucks.com/forum/new-builds/60677-bitfenix-prodigy-living-room-gaming-build-help.html)
jrfox87 April 12, 2013 11:21 AM
Hello everyone. It's been about 5 years since my last build and I'm looking to build a gaming rig next month for use in my living room on my HDTV. I've been researching online and have a list of parts that I currently have picked out. I am just looking for opinions on the parts I've picked out or if you have suggestions or alternatives that would be great too.
1. What YOUR PC will be used for.
Mostly just gaming on my HDTV. Skyrim, Tomb Raider, Bioshock Infinite, Crysis 3, and Simcity are the games I's currently playing. I'd like to run the games on the highest settings I can of course.
2. What YOUR budget is.
Approximately $1300 before taxes and shipping
Canada
4. IF YOU have a brand preference.
Nope
My HDTV as the monitor, keyboard, mouse, wired xbox controller
I have read a couple threads and done some research, have a list of parts I'm considering. Just want opinions on the parts I'm considering and any suggestions you may have.
I have no plans to overclock and likely never will.
Haven't bought any parts yet. I plan on building it next month.
9. What resolution and settings do you use?
Since this is for use with an HDTV, the resolution will be 1920x1080. I'd prefer to play on High-Max settings.
10. Are there any specific technologies you want?
USB 3.0, SSD, SATA3 6.0Gb/s
Here are the parts I'm looking at getting:
Case: Bitfenix Prodigy
Front Case Fan: BitFenix Spectre Green LED 200mm Fan
CPU: Intel Core i5-3570 3.4GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper TX3
Motherboard: Gigabyte GA-H77N-WIFI Mini ITX
RAM: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
PSU: Corsair CX 600W 80 PLUS Bronze
Storage: Intel 120GB 520 Series Cherryville SSD & Western Digital Caviar Black 1TB
Video Card: EVGA GeForce GTX 680 2GB
Thanks in advance for any hep anyone can give me. :)
bliz April 12, 2013 11:41 AM
Haha it's already perfect,nothing to say about that build,maybe a 80+ gold PSU?Just for premiumness?
Or take a radeon 7970 ghz instead,it's less expensive and just as good.
Tech686239 April 12, 2013 11:49 AM
Yea. I think the 600 watt PSU is fine. The only thing i was thinking about is there is no room for expansion. Maybe alittle bigger PSU.. that is the only thing i would change
Bond007 April 12, 2013 11:54 AM
Your choices are fine and you would have no issues with it. My thoughts for your consideration:
Case: Bitfenix Prodigy - Good to go
CPU: Intel Core i5-3570 3.4GHz Quad-Core Processor if your on an H77 board and have no intentions of overclocking I would save a few bucks and get a 3470. If you will OC go to a Z77 motherboard and a 3570k (not sure if there are any with built in WIFI...may have to get an add on card)
CPU Cooler: Cooler Master Hyper TX3 I am not familiar with what will fit in that case. I would just use the stock heatsink if not OCing. I wouldn't bother with a TX3 personally (not that great).
Motherboard: Gigabyte GA-H77N-WIFI Mini ITX see CPU comments above...otherwise good to go
RAM: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory good to go
PSU: Corsair CX 600W 80 PLUS Bronze this is fine, but I would go to a higher quality model. Corsair TX/AX/HX, XFX, Antec, Seasonic. I would also opt for a 650w, but 600 is more than enough
Storage: Intel 120GB 520 Series Cherryville SSD & Western Digital Caviar Black 1TB good to go
Video Card: EVGA GeForce GTX 680 2GB for 1080p I wouldn't bother with more than a gtx 670...but obviously there is nothing wrong with a gtx680
Soullessone21 April 12, 2013 12:06 PM
CPU: Intel Core i5-3570 3.4GHz Quad-Core Processor [B]if your on an H77 board and have no intentions of overclocking I would save a few bucks and get a 3470. If you will OC go to a Z77 motherboard and a 3570k (not sure if there are any with built in WIFI...may have to get an add on card
MSI!!!!!!!!!!!!!!!!!!!!
MSI Z77IA-E53 mITX LGA1155 Z77 DDR3 1PCI-E16 SATA3 HDMI USB3.0 Motherboard
annnnnd for cooler get the
Noctua NH-L12 LGA1155/1366/2011 AM3 FM1 FM2 Low Profile Heatsink Cooler w/ NF-F12 120mm NF-B9 92MM
and last but not least get a
660 or a 7870 way more than enough power for 1080p TVs
ZZLEE April 12, 2013 01:49 PM
Seasonic X up to 850 will fit in the 160 mm Hole. Yah the 850 X is a little cramped but she works nice.
jrfox87 April 12, 2013 01:53 PM
Thanks for your suggestions.
Based on what you said I'm thinking I'll drop the CPU cooler and just use the stock one from intel as well as up the Corsair power supply to the TX650W model.
ZZLEE April 12, 2013 02:05 PM
The power supply bay is cramped make sure it will fit.
jrfox87 April 12, 2013 02:30 PM
Yea, I've heard it's pretty cramped but I have seen other people's builds with the Prodigy using the TX650M power supply and they managed it without modding the case in anyway so I'm pretty confident I shouldn't have any real issues with it.
Chasingu April 12, 2013 08:08 PM
Just my two cents, I've had a horrible experience with a TX power supply. It started randomly shutting down the computer after 2 days of use. Swapped it for a AX and that has been working perfectly ever since. Again, just my two cents.
