Old April 10, 2013, 06:53 AM
Question Built new machine for work. We have a bit more $,what do you think we should upgrade?
We just had a machine built for development at a local store. We're building a second one with a bit more funds. What do you think is the bottleneck of the system and how can we improve it?
Specs:
INTEL CORE I7 3930K 3.2GHZ
SAPPHIRE RADEON HD7970 3GB
2.5 SATA3 240.0 INTEL SSD 335 BTE A4K5
2x SATA3 1.0TB W.D 7200 RPM
S2011 GIGABYTE GA-X79-UD3 X79 [Motherboard]
BD-R BLU-RAY LG BH14NS40 SATA LS 14X
850W ATX CORSAIR TX MODULAR OEM [Power Supply]
CORSAIR VENGEANCE 1600MHZ DDR3 32GB QUAD 4X8GB CL10 [RAM]
Thank you for your help!
Psycho-Designs.com
Desktop: Q6600, Evga Nforce 780i, MSA GTX 660Ti 3GB, 8GB DDR2 OCZ Platinum.
Laptop: Sager 8660: 15.4" 1680x1050 screen, P9500, GeForce 9800M GT, 4GB DDR3.
Old April 10, 2013, 07:16 AM
great_big_abyss's Avatar
How much more money? What is the actual use of the workstation?
Go multi-monitor, and if the money is there, IPS panels.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old April 10, 2013, 07:45 AM
stoanee's Avatar
Get a good cpu cooler and overclock to at least 4ghz.
heatware
Old April 10, 2013, 08:23 AM
Get a second SSD and put them in RAID 0. Great rig as it is though.
i7 3770K, 4.7GHz at 1.33V, ASROCK Z77 Extreme4, 2X4GB Patriot Viper Black Mamba DDR3 1600, GTX 590, 2 Corsair Force 3 120GB SSDs RAID 0,2 Barracuda 7200.10 500GB, Barracuda 7200.11 1000GB Back Ups, OCZ ZX 1250W, Z-5500s, LG Blu Ray Player/DVD Burner, Windows 7 X64 Pro, HAF X. Vision Quest 24" LCD, Optoma H66 Projector
Cooling: TC PA120.2 GT AP15 in push, DDC 3.25/XSPC Res top, EK Supremacy, XSPC Razor, Coolgate CG-240 Swiftech Helix in push/pull, MCP35X
Old April 10, 2013, 08:26 AM
Caldezar's Avatar
GBA asked the right question... what is it being used for? 'Development' is very vague. In most software development situations, I would be dropping the GPU down to something like a 7850, and taking the extra money, combined with the savings on the GPU, and buy 2 or 3 large monitors. I know that if I was working in development, I'd be way happier with more screen real estate rather than a gaming GPU I was never going to use.
Also, yes, a decent cooler that allows a reasonable OC isn't a bad idea.
*EDIT* - I'd tend to disagree with RAID 0 SSD's on a workstation as reliability is way to important in a work environment.
Old April 10, 2013, 10:36 AM
It's for game development. There already are 2 large monitor without the desk space for a 3rd one. We have about $300-$400 to upgrade the new machine. The idea is to have it as future proof as possible and iron out any performance bottlenecks.
Psycho-Designs.com
Old April 10, 2013, 10:47 AM
Caldezar's Avatar
Ah... game development is a different story. Definitely wanting to keep the GPU you have. I'd still avoid RAID though.
Definitely get a solid cooler and OC the chip.
You might want to consider increasing to one of the new 960GB SSD's from Crucial. At $600, that's a solid price point. Or maybe even spend the money on upgrading those HDD's to enterprise level 2TB drives. Space is quickly going to become a premium if you're working on large scale 3D models.
Old April 10, 2013, 11:04 AM
In that case, drop the SATA SSD, and plop in a decent sized (480GB?!?) OCZ RevoDrive.
Old April 10, 2013, 11:15 PM
I would get an nvidia card just to be able to test performance on both vendors
Tags
bottleneck , game , games , specs , upgrade
Attempt #16 to get work failed, and no other work to do Shadowmeph HardwareCanucks F@H Team 7 January 5, 2012 03:33 PM
Attempt #10 to get work failed, and no other work to do. LaughingCrow HardwareCanucks F@H Team 3 May 5, 2010 08:29 AM
[WTT] WTT or Sell Dell XPS M1710 Laptop for smaller work friendly machine ToXic Buy/Sell & Trade 7 August 28, 2009 09:01 PM
Machine burnt out. New machine needed Neutronium New Builds 15 March 18, 2009 12:23 AM
In need of an upgrade - Will this work ? excalibur55 Video Cards 19 February 10, 2009 06:49 PM
