Old March 24, 2013, 10:14 AM
Default Problem
Yeah, so I've been having a bit on an issue with my computer where it has trouble resuming and starting up after going into sleep mode.
If my computer goes into sleep mode whether by me pressing the button or allowing the computer to eventually fall asleep by itself after being idle, it won't come back on. It will still be powered on, but wiggling the mouse or keyboard has no effect. The power button remains flashing blue like it's idle instead of turning blue like it should. It does occasionally actually go blue again, but it never seems to actually come back on. After this occurs, I have to restart it manually several times just to get it to boot properly or unplug the power cord and plug it back. Also, the computer won't put out any kind of video signal. I've also noticed my performance has been a little shoddy when running multiple applications, lately. Not horrible, but a little sketchy.
I'm hoping it isn't a hardware failure and it's something that can be remedied by a soft fix. But some people did tell me it is a HDD problem
Anyone has a better explanation/solution?
Thanks!
Old March 24, 2013, 11:14 AM
I have read about motherboards thta have an issue like this. What hardware?
i7 3770K, 4.7GHz at 1.33V, ASROCK Z77 Extreme4, 2X4GB Patriot Viper Black Mamba DDR3 1600, GTX 590, 2 Corsair Force 3 120GB SSDs RAID 0,2 Barracuda 7200.10 500GB, Barracuda 7200.11 1000GB Back Ups, OCZ ZX 1250W, Z-5500s, LG Blu Ray Player/DVD Burner, Windows 7 X64 Pro, HAF X. Vision Quest 24" LCD, Optoma H66 Projector
Cooling: TC PA120.2 GT AP15 in push, DDC 3.25/XSPC Res top, EK Supremacy, XSPC Razor, Coolgate CG-240 Swiftech Helix in push/pull, MCP35X
Old March 24, 2013, 11:37 AM
Shadowmeph's Avatar
which OS are you using most likely it is a hibernation problem try pressing the Enter key or turning hibernation off ,rebooting and turning it back on again or sometimes it is not enough ram for the system to have hibernation running
Old March 24, 2013, 02:06 PM
My specs :
APU/CPU : AMD A8-5600K APU Quad Core Processor Socket FM2 3.2GHZ 4MB 100W Retail Box
Motherboard : ASUS F2A85-M/CSM mATX FM2 85X FCH DDR3 2PCI-E16 1PCI-E1 1PCI SATA3 DVI HDMI USB3.0 Motherboard - DirectCanada
PSU : Corsair CX Series CX430M 430W ATX 12V 80 Plus Bronze Modular Power Supply - DirectCanada
HDD : Western Digital Caviar Blue 1TB SATA 6GB/S 7200RPM 64MB Cache 3.5in Hard Drive OEM
RAM : Corsair Vengeance CMZ8GX3M2A1600C9 8GB 2X4GB DDR3-1600 CL9-9-9-24 Dual Channel Memory Kit - DirectCanada
Case 2 : Antec One Mid-Tower Gaming ATX Case Black 3X5.25 5X3.5 2X2.5 Front USB3.0 Top Rear 120mm Fans No PSU - DirectCanada
Windows 7 64 bit, torrent, but i tried 2 different with same problem
I only did "sleep mode" to consume less energy but now, with that problem, i won't put it to sleep anymore, but i would really like to know what is causing that
because i just bought my new computer (1 month ago)
Thanks!
Old March 24, 2013, 04:56 PM
rfglass's Avatar
I have heard issues like this b4, Most of the time it was a usb peripheral like a keyboard or mouse that keeps the pc from waking up.
Could a hardware problem cause a driver problem? LaughingCrow Troubleshooting 4 January 19, 2012 11:46 AM
Steam connection problem (Problem Fixed) great_big_abyss Gaming 3 January 10, 2012 05:37 PM
Hard drive problem or Windows 7 Problem?! aeminence New Builds 4 October 13, 2011 06:46 AM
could this be a game problem or a video driver problem? Shadowmeph Troubleshooting 4 December 17, 2010 07:01 AM
Hardware problem or HAL problem? andynerd Troubleshooting 1 March 7, 2009 09:03 PM
