-   -   Buying used or build (http://www.hardwarecanucks.com/forum/new-builds/60314-buying-used-build.html)
OBNO March 21, 2013 04:03 PM
Had a post earlier on some used set up and fell thru. I've now come upon 2 systems advertised #1 for $1600 all parts between 1 and 3 months receipts available I think I may be able to get it for $1500 is it to much and should I go for it or not. Then there's a water cooled available they were asking $1300 it can be had for $1050.00
So my question is what one should I go for I'm favoring the I3570K and are the prices good?
Specifications are:
Case and Fans - Thermaltake Chaser MK-1 ATX Full Tower Computer Case 4X5.25 6X3.5 INT USB 3.0
- 2 X Rosewill RFA-120-BL 120mm 4 Blue LEDs LED Case Fans
Motherboard - MSI Z77 Mpower ATX LGA1155 Z77 DDR3 3PCI-E16 4PCI-E1 SATA3 DVI HDMI VGA SLI USB3.0
CPU - Intel Core i5 3570K Unlocked Quad Core Processor LGA1155 3.4GHZ Ivy Bridge 6MB Retail
SSD - Intel 330 Series 180GB 2.5in SSD MLC 25nm SATA3 Solid State Disk Drive Retail Maple Crest
HDD - Western Digital AV-GP 1TB 64MB 3GB/S SATA 3.5IN Internal Hard Drive OEM
CPU Cooler - Corsair Cooling Hydro Series H100 Extreme Performance CPU Cooler System LGA1366 2011 1156 1155 AM2 AM3
- Corsair Air Series SP120 120MM 2350RPM 62.74CFM 35DBA High Static Pressure Fan Dual Pack
GPU in SLI - ASUS GeForce GTX 660 Ti DirectCU OC 1058MHZ 2GB 6GHZ GDDR5 2xDVI HDMI DisplayPort PCI-E Video Card (DC2O-2GD5)
Memory - Crucial Ballistix Tactical Tracer Orange+Blue LED's 16GB 4X4GB PC3-12800 DDR3-1600 1.5V CL8
PSU - Cooler Master Silent Pro M2 850W 80+ Silver ATX 12V V2.3 Power Supply 20/24PIN w/ Silent 135mm Fan
OR i can get the following for $1050.00
System Highlights:
XFX Radeon 7970 HD Double D
ASUS Maximus V FORMULA
Intel Core i5 2500K Quad Core Unlocked Processor
Seasonic X Series 760W Power Supply
Corsair Neutron Series GTX 240GB SATA3 Solid State Drive
G.SKILL TridentX 8GB (2X4GB) DDR3-2400 Memory.
Water Cooling loop Higlights:
Swiftech MCR140-QP Radiator - Single 140MM Fan
Swiftech MCR240-QP Radiator-Dual 140MM Fan(s)
Swiftech MCP35X Pump and Reservoir
Swiftech KOMODO-HD7970 Full Cover VGA Waterblock
Alphacool NexXxoS XP≥ Light - Acetal Edition - CPU Waterblock
Thanks folks will wait for feedback :)
