Old March 21, 2013, 02:08 PM
Mark's Avatar
Default laser / water cooling
Any idea where I can get some work done to the front of my case ? It's lian li so it's 1.5mm thick.
In GTA are ( Greater Toronto Area. )
How much would it cost ? Looking to cut out the Rampage logo on the front :
CHEERS
Old March 21, 2013, 11:48 PM
Bungwirez's Avatar
You mean something like this?
DIY with dremel.
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old March 26, 2013, 03:19 PM
Wow that panel looks so good. Good cut bro. Ps love the image in the reflection
Old March 26, 2013, 04:59 PM
Mark's Avatar
I have a dremel what did you use to cut it out with ? bits ?
CHEERS
Old April 26, 2013, 03:24 PM
Best to use a stencil.
Old April 26, 2013, 04:08 PM
KaptCrunch's Avatar
means mask tape the area then use a stencil to mark you cut out
Old April 26, 2013, 04:14 PM
KaptCrunch's Avatar
mark call them up an see what they want
100 Hanlan Road, Unit 6 Woodbridge Ontario L4L 3P6
Phone: (905) 850-3192 Fax: (905) 850-8475 info@antechtechnologies.com
Old April 26, 2013, 08:38 PM
Bungwirez's Avatar
I just stencilled the back side, then cut out with dremel. went over edges with dremel finishing bit to smooth it out. took about two hours... mostly cause I was using cheapo cutting wheels - broke about 6?
thanks KaptCrunch... that will help me soon too I hope.
Old April 27, 2013, 08:17 AM
TripT Computer Customs
Aquarium gear for water cooling??? WATER CHILLER??? clshades Water Cooling 6 March 15, 2012 09:21 PM
New To Water Cooling mjbdc07 Water Cooling 10 August 31, 2010 05:25 AM
New to Water Cooling fishingfanatic Water Cooling 4 April 30, 2010 09:36 PM
SLI Water Cooling. BALISTX Water Cooling 5 March 19, 2008 10:02 AM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
