I want to build a small gaming PC that has the following qualities: quiet, snappy, low temps. Also, it must be able to run recent titles at 40+ FPS on medium/medium-high settings. I already have: extra storage, dvd drive, WIN7 64bit, peripherals.
I would like to know whether or not this is a balanced build, or if there are flaws that must be corrected.
The following components are copy/pasted from Newegg.com. Almost all have promo codes and/or rebates.
Case - Rosewill LINE-M
Micro-ATX Mini Tower Computer Case, Dual USB 3.0, come with Dual Fans, Support up to 4 Fans, 12.5" card
MOBO - ASRock H77M LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0
Micro ATX Intel Motherboard
PSU - COOLER MASTER
Silent Pro M2 RS620-SPM2E3-US
620W ATX12V V2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Full Modular Active PFC Power Supply
GPU - MSI N660Ti PE 2GD5/
OC GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
CPU - Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
RAM - G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3
1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
SSD - SAMSUNG 840 Pro Series MZ-7PD128BW 2.5"
128GB SATA III MLC Internal Solid State Drive (SSD)
Heat sink - COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/FM2/AM3+
This heat sink is a monster. It looks hilarious on a Micro ATX board.
