Old February 26, 2013, 10:58 PM
Default Build has begun, need some help
So I went tonight and bought the first few things for my new build.
I got a Corsair 650D as my case
Corsair h100i for cooling
a intel 3770 CPU
and a corsair 850 ax pro fully modular power supply, think i remember all the names properly all the stuff is downstairs in my living room.
Now I am going to go in the morning and buy a Motherboard (around $300) what should I get?
A video card, thinking nvidia 680, a asus one? whats the best to go with?
and I need RAM, I like the corsair dominator platinum 16GB (4x4)DDR3 1866Mhz CL9 kit, does that sound good?
I am thinking for a video card GTX680 Direct CU II GeForce GTX 680 4GB PCI-E w/ Dual DVI, HDMI, DisplayPort
Is there a better option? I'm willing to spend $600 on the video card.
Help ASAP, I work up north in the oil sands and I am on my one week off before i go back for another 2 weeks or 3 weeks of work, and I want to get some game time in before I go back to work, so Ill be buying the rest of the parts tomorrow.
Old February 27, 2013, 12:10 AM
Dzzope's Avatar
If your a new member you can't edit your posts. you need to re-post.
My first build: Final revisions-Help&Advice (budget build) HigginsHere New Builds 4 October 9, 2012 07:56 AM
Wanting to build a Home File Server, thoughts on this build? Silver_40 New Builds 4 September 19, 2012 10:36 PM
New Build- Corsair 800D --> My cleanest build ever. Watercooled btdvox Case Mods, Worklog & Gallery 28 May 11, 2010 01:07 PM
Water cooling project has begun nckid4u Water Cooling 0 May 19, 2009 05:04 AM
Build 4 a CDN Soldier Worklog - It Has Begun BALISTX Case Mods, Worklog & Gallery 25 February 2, 2009 06:53 AM
