Old March 13, 2013, 06:09 PM
Okay. It's been a while but I've revised my list. Thanks for all the help guys.
Motherboard- MSI AMD 990FXA-GD65 V2
CPU- AMD FX-8350 Eight-Core 4GHz
GPU- Asus Radeon HD 7770 HD7770-2GDDR5 Video Card
RAM- Kingston HyperX Black KHX16C9B1BK2/8 8GB Desktop Memory Module Kit (1600 mhz)
PSU- Corsair CX500 V2 CX Series CP-9020047-US 500W Power Supply - 80 Plus Bronze
Optical Drive- Samsung SH-224BB/BEBE Internal 24X DVD Burner
Case- Cooler Master RC-430-KWN1 Elite 430 Mid Tower ATX Case
Total Price- $634.82
P.S. I got a copy of Windows 7 thanks to a friend. :)
I'm going to order all of these parts within a week. I'll check back here frequently just in case there's something that needs to be changed.
Old March 13, 2013, 06:23 PM
Bungwirez's Avatar
Cool Master Elite 310 for TEN BUCKS!!!
I would really make sure that you can actually find that in stock, before you commit your budget.
derp... ninja posted.
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old March 13, 2013, 06:25 PM
ShinraCorp's Avatar
Just make sure it's a 64-bit Windows 7! :P Or else Windows will only use 4 GB of RAM instead of 8.
Tags
cod , cpu , gtx 650 , intel 3570k , low budget build
My first build: Final revisions-Help&Advice (budget build) HigginsHere New Builds 4 October 9, 2012 07:56 AM
First Build: $6,000 Budget WillieMammoth New Builds 26 December 11, 2010 04:32 AM
Budget build. Epmphasis on budget. Miek New Builds 6 February 4, 2010 10:46 PM
Low Budget Build Toyuko New Builds 2 January 14, 2010 10:17 PM
PSU for budget build somecanadianguy Power Supplies 36 October 29, 2009 05:30 PM
