Well again some good advice and some intriguing advice about that hybrid 750GB drive, I again went with Dzzopes suggestions with a few changes. Mostly in regards to the motherboard
Whitelight77 - Saved Builds - PCPartPicker Canada MSI Z77A-G45 Thunderbolt ATX LGA1155 Motherboard to a
Asus P8Z77-V LK ATX LGA1155 Motherboard simply because the asus one is a bit cheaper and it seems like the only difference is the MSI has a greater range of memory type being 1066 at the lowest and 2800 at the highest as opposed to the 1333 and 2400 of the Asus. Considering I'll be using 1600 ram the Asus seems to be a reliable choice (I could be wrong but that's what it seemed like). If I don't hear any imput about the motherboard I may revert back to the MSI Thunderbolt just to not mess with synergy. The
Seagate Momentus XT 750GB 2.5" 7200RPM Internal Hard Drive I find intriguing and I'd like to try that out. I'll get it from NCIX because it's $20 cheaper through them but it's on this list just to tie up the complete package(I tried suggesting Ncix in the suggested retail box but it never took). If anyone knows anything scandalous about the hybrid drive then please let me know. Otherwise I feel like i'm zeroing in on my final build.
Oh and AKg, you said the Mushkins were a tad long in the tooth. Do you mean the male/female connection prongs? Again I'm extraordinarily green in these matters. Also how would this affect me? If it's a room inside case issue or perhaps connectivity isues?
I also like the case that Akg suggested, the price is good and it's in black which will match a bit better. If I were to get the hybrid drive then I can also get the tower from NCIX, as long as the tower can house the motherboard.
In fact i already ordered a couple parts from NCIX, the only question now is between the 2 motherboards that are listed above in this box. After that it's all about ordering in, I want my new comp by next week :D so excited.
