Old January 1, 2013, 07:18 PM
Bond007's Avatar
Passmark is one I used a while ago that if I recall correctly shows everything.
Desktop: Arc Midi R2, Z77-D3H, 3770@4.1ghz with Zalman Optima Cooler, 4x4gb ram, EVGA GTX 1070 Ti SC, Bitfenix Fury 750w, WD Black 1TB, MX500 500gb
Away from home: Lenovo Legion Y530, 16gb, i7 8750H, GTX1050Ti
Old January 1, 2013, 07:59 PM
Thx for the input got results Used: Passmark
System Summary
System Information
System Name: SOLIDCREE-PC
Operating System: Windows 7 (64-bit)
Motherboard Manufacturer: Gigabyte Technology Co., Ltd.
Motherboard Model: GA-990FXA-UD3
Motherboard Version: x.x
BIOS Manufacturer: Award Software International, Inc.
BIOS Version: F8
BIOS Release Date: 05/30/2012
CPU Information
Manufacturer: AuthenticAMD
Type: AMD FX-6100 Six-Core
Number of CPU's: 1
Cores per CPU: 6
Hyperthreading: Not capable
Measured Speed: 3323.4 MHz
Multiplier: 17X
L1 Instruction Cache: 6 x 16 KB
L1 Data Cache: 6 x 64 KB
L2 Cache Size: 6 x 2 MB
L3 Cache: 8 MB
Memory Information
Total Physical Memory: 8173 MB RAM
Available Physical Memory: 6882 MB RAM
Slot 1: Not populated
Slot 2: Not populated
Slot 3: Unknown, 4096MB, 1600MHz
Slot 4: Unknown, 4096MB, 1600MHz
Virtual Memory: C:\pagefile.sys (8173 MB)
Disk Information
Drive Letter (Number): C (Physical drive 0)
Model Number: ST2000DM001-1CH164
Disk Size (Free space): 1862.9 GBytes (1768.7 GBytes)
Disk Cluster Size: 4 KBytes
File System: NTFS
Video Adapters
Description: AMD Radeon HD 7870
Chip Type: AMD Radeon Graphics Processor (0x6818)
DAC Type: Internal DAC(400MHz)
Memory: 2048MB
Video BIOS: 113-787CNF83_113-AD42800-100-XF
Driver Provider: Advanced Micro Devices, Inc.
Driver Version: 9.2.0.0
Driver Date: 9-27-2012
Monitor 1: 1600x900x32 60Hz (Primary monitor)
Note the Ram speed.
Old January 1, 2013, 08:04 PM
First off.. Change this to a static size of 2048MB and forget about it
Microsoft Corporation
Second is your ram in slots 3 + 4? Should be in 1 + 2 and do you have XMP profiles set?
Old January 1, 2013, 08:23 PM
I installed according to the manual and motherboard that says on both : Ram4|Ram2| Ram3|Ram1| that's how it was marked out in order
What's XMP and where do I find it? or find out if it as it?
I should do more reading up on these things before messing it up permanently.
Old January 2, 2013, 05:16 AM
Bond007's Avatar
In the bios what is the ram speed set too(or ram multiplier or ram ratio...something along those lines)? Often you have to manually set the speed.
Old January 2, 2013, 06:05 AM
great_big_abyss's Avatar
According to your motheboard manual:
For optimum performance, when enabling Dual Channel mode with two memory modules, we recommend
that you install them in the DDR3_1 and DDR3_2 sockets.
Old January 2, 2013, 07:47 AM
It's gotta be my bios settings that's needs adjusting. Still reading up on it and yes I got the ram sticks in the right slots, thinking passmark is not fully compatible with windows 7.
F- Stream Tuning Z68 mobo Warcrimes O/S's, Drivers & General Software 4 February 5, 2012 11:50 AM
Intel Launches Performance Tuning Protection Plan On Select Processors EmptyMellon Reviews & Articles from the Web 15 January 19, 2012 12:28 PM
DD-WRT fine tuning The Quicken Networking 10 August 28, 2011 08:04 PM
Gaming Computer for under $1000(USD) AmuseMe New Builds 14 January 26, 2010 10:43 PM
Custom High-end gaming computer (New Help)Budget $850-1000 pickedup New Builds 7 November 15, 2008 02:25 PM
