Old December 29, 2012, 06:04 PM
supaflyx3's Avatar
Default $500-$600 Upgrade build
My friend is upgrading his PC and has a decent budget, so I'm going to help him out and show him how to build it
ARMA 2, DayZ Standalone, Borderlands 2, web surfing, media play back & photo editing
$500-600 including taxes and shipping if required.
Canada
4. IF YOU have a brand preference.
No brand preference
Optical drive, CPU (Q8200) maybe board (OEM acer board)
yes
Planning on overclocking if budget can include new board
within the next 2 weeks
9. What resolution and settings do you use?
720P
10. Are there any specific technologies you want?
SSD
Decent case
Possibly video cards with game bundles.
Old December 30, 2012, 12:39 PM
Sadly, the motherboard and CPU are too dated to reuse.
Your budget is low, and you're gaming at 720p (which is low by enthusiast standards), so I would recommend going the AMD route.
Here is a build centered around the FM2 processor and the A85 chipset:
Gigabyte F2A85XM-D3H: motherboard: 94.99
Gigabyte F2A85XM-D3H w/ DDR3 1866, 7.1 Audio, Gigabit LAN, VGA, DVI-D, HDMI at Memory Express
A10-5800K APU: Processor: 124.99
AMD A10-5800K APU, Black Edition 3.8GHz w/ 4MB Cache at Memory Express
Gskill 1866 8 gig cas 9 kit: memory : 49.99
G.SKILL Sniper Series 8GB PC3-14900 Dual Channel Kit (2 x 4GB) at Memory Express
500GB WD Caviar Blue: Main Storage Drive: 64.99
WD 500GB Caviar Blue 7200rpm SATA III w/ 16MB Cache at Memory Express
Intel SSD 520 Series SATA III Solid State Drive, 60GB: 89.99
Intel SSD 520 Series SATA III Solid State Drive, 60GB at Memory Express
Corsair Carbide Series 200R Compact ATX Case: 64.99
Corsair Carbide Series 200R Compact ATX Case, Black at Memory Express
Corsair CX500 500W Power Supply: 54.99 (Cheapest corsair PSU with 2xpcie connectors for upgrades).
Corsair Builder Series CX500 500W Power Supply at Memory Express
544.93 Total at Memory Express.
Won't slay the top games, but you'll have a good gaming experience with all 720p gaming at reasonable settings. It also has the potential to upgrade to a much more powerful video card as the PSU has the two PCIE connectors needed to power beast cards.
Old December 30, 2012, 05:24 PM
supaflyx3's Avatar
the CPU is fine for his needs, he isn't expecting to max every game out there he just wants to run it over 30fps on medium-high settings.
Old December 30, 2012, 05:27 PM
Soullessone21's Avatar
Delete some PM's so I can argue with how wrong you are about everything on here in private :P JK your inbox is full and I cannot assist you with your RMA without somewhere to pm
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
Old December 30, 2012, 06:48 PM
The problem that I forsee is that many of the socket 775 mobos are not ddr3 and thus you cannot get cheap 8 gigs of memory.
Also you said you want SSD. SSD kinda sucks without sata 6GB. That motherboard might not even have sata 2 ports being so old.
Also, acer motherboards aren't exactly top of the line, and socket 775 is old. Your capacitors run the risk of blowing out after so many years of use.
Upping to a brand new system is my best suggestion, and if you don't like the amd APU, you probably can configure an i3 system just as cheap with a budget video card.
Old December 30, 2012, 07:35 PM
supaflyx3's Avatar
His motherboard is DDR3, I've run SSDs on sata2 and they were fine and snappy, thanks for the suggestions though.
Old December 30, 2012, 08:56 PM
720p doesn't exist afaik on desktop only laptops. you either play in a 16:10 resolution or 1080
Old December 30, 2012, 10:36 PM
supaflyx3's Avatar
1366x768.. that's 720p.
Old December 30, 2012, 10:40 PM
and what monitor is going to display that natively?
even a 21.5 monitor is still 1080. you would again need a lcd type panel.
Old December 31, 2012, 12:14 AM
dustin1706's Avatar
The Q8400 is a bit outdated at this point, but for casual gaming and basic use it will work. I still have a Q6600 running in my spare rig and I haven't run into any problems with it. And, he can always upgrade to like an i5 3300 and sub $100 mobo later if he needs more performance, sata 3 or usb3. Assuming he has peripherals, monitor and an os?
If it were me and keeping it to $600 I wouldn't be dead set on the exact components I'd shop the sales and pricematch what I can, but it might look something like this:
Prices from NCIX 30-Dec-2012
Kingston KHX1600C9D3B1K2/8GX 8GB Kit 2X4GB 1600......36.99
Antec Basiq VP450 450W Power Supply........................44.99
Samsung 840 Series 120GB........................................118.9 9
Corsair Vengeance Series C70....................................89.99 (or HAF912, P280 , carbide 200 or whatever he likes for ~100)
MSI Radeon HD 7870 OC Twin Frozr III........................199.99
Western Digital Caviar Blue 1TB.................................69.99
=$561
Plus shipping and maybe he wants a few fans or lights.
I don't see any good card/game bundles right now. Too bad because I bought a 650 a month ago for $99.99 and it came with Nexusz, Shogun 2, Dirt showdown and Assassin's creed 3.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Upgrade Build OhSlowpoke New Builds 16 January 18, 2012 02:19 PM
NEW BUILD vs. UPGRADE HOTDOGS New Builds 15 November 30, 2011 10:27 AM
Advice on new build/upgrade KonstigtSjael New Builds 4 February 1, 2011 02:30 AM
upgrade/new build timidestemu New Builds 9 January 28, 2011 08:29 AM
Upgrade.... or new build? belinik New Builds 7 September 9, 2010 05:33 AM
