Old December 22, 2012, 08:56 PM
Default PC Build Help. Noob Here! First post.
Hello guys. I'am coming from a car forum (r3vlimited) this is my first post. I'am a complete noob when it comes to this. When people start discussing pc set ups it's seriously like a foreign language to me. Hoping you guys can help me over here! :)
Originally Posted by draemn
I would like to see either a slight modification or some 'descriptions' added to help guide people posting with this format.
My PC will mostly 90 percent be for gaming. The games I play are Counter Strike, Starcraft 2, DOTA, HON, BF3 and maybe get into Diablo 3. I'am a college student so once in a while use it for Microsoft word, Power point etc. I want this PC to run all my games really smooth at possible max settings?
My budget is 2k-2.2k Somewhere around those lines? this includes all necessary components to run the actual PC, Mouse, Monitor, keyboard, OS everything.
U.S. specifically tigerdirect.com
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy,
Not to sure but i've heard Intel is the way to go?
I wanna start Brand new everything
Ha lets see what i know. or what i have heard. I5>I7 intel processor for gaming. Dont get top of the line stuff. Gaming tech changes every year and price difference is craxy for best set up to second best set up.
umm more memory the better. trying to max out on a 32gb memory? that about it?
I have no clue what that means.
I have nothing together and a family friend will put it together. He's alot older then me. Always busy I called/texted he never replied to me about what to buy. But im sure if I bug enough he will come to put it together lol.
9. What resolution and settings do you use?
No 3d. but i'd like to run everything in max graphics if that makes sense?
10. Are there any specific technologies you want?
I read that getting a SSD is really good for a nice set up. Um I5 is the way to go and I want to max out 32gb memory?
These setups was what i was thinking..
(forum member told me I would get flamed and not to buy bundles lol)
what do you guys think?
If you have any suggestion try to keep @ tigerdirect? they have financing :)
GIGABYTE GA-Z77-DS3H Intel 7 Series Motherboard and Intel Core i5-2500K 3.30GHz Quad-Core Unlocked CPU and Kingston HyperX Red 4GB Memory Module and Kingston HyperX Red 4GB Memory Module and WD Bundle at TigerDirect.com
Asus Sabertooth X79 motherboard, Intel Core i7 3930K LGA2011 CPU, Corsair Hydro H80 CPU Liquid Cooler, Corsair Dominator 32GB DDR3 Kit (4x8GB), Seagate 1TB HDD, BluRay DVDRW, Thermatake Case/700w PSU at TigerDirect.com
Please be patient with me and keep in Mind this Sh*t is like a foreign language for me! Thanks for having me hear and hope you guys can help! any criticism and advice is welcomed :)
Old December 22, 2012, 11:10 PM
rjbarker's Avatar
^ The key will be something you missed above..What Resolution? Most are going with a 1920 x 1080 Res, some of us enthusiasts are going for larger monitors with higher Resolution, such as 27" 2560 x 1440 or 30" 2560 x 1600, the latter sizes require a PC with some good "Poop", the 1080 Resolution requires "less poop" ;)
Dont confuse size of screen with Resolution...as in a 60" Flatscreen is 1080....same as a 22" Monitor that is 1080...the higher the Resolution the crisper the details look.
The Z77 chipset you have would be where to start, the I7 X79 chipset (the 2nd one listed) would likely be more than you need, unless of course you ultimately want the 2 higher resolution Monitors I pointed out above (2560 x 1440 or 2560 x 1600), then indeed the X79 would suit your needs fine.
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old December 23, 2012, 01:03 AM
I think you should get a more solid commitment from your friend or do some research on doing a build, it's relatively easy but it's nice to have someone help the first time, especially if you're dropping 2 grand.
This is a totally random build but I think it's pretty representative of what you can/should get for about that much if you have to buy everything:
Intel Core i5-3570K, Asus Radeon HD 7950, Corsair 500R Black - System Build - PCPartPicker
Old December 23, 2012, 08:21 AM
Cool thanks for the setup ill look into it and see if I can buy that stuff @ tigerdirect.
So I should start leaning more towards my second choice? Yea I think 1080 is good enough for me. I can't picture myself playing with a 27' or 30' screen. I'm happy with a 25 I guess. I don't think I would be able to tell the difference between 1080 and anything higher haha.
And other thoughts?
Old December 23, 2012, 08:55 AM
Overclocking is when you take your processor for instance and make it run faster than it was meant to. For instance if you make a 3GHz Processor run at 4GHz thus making it faster. It seems that you are not going to do that in which case I wouldn't recommend going for a processor with a "K" in the name since that K means it's good for overclocking. So I'll recommend either a i5-2500 (no K) or a i5-3450 or i5-3570 instead of the i5-2500K you've listed in build #1. It'll save you some money simply because you don't need a K for a non-overclocking build. Should you however choose to overclock at a later point, you'll need a K-processor. Other than that I'd probably take i5 over i7, again to save some money where you don't need to spend them.
You were talking about 32 gigs of RAM and while it is true that the more memory the better, at the moment I don't think you need to get anymore than 8gigs of ram. Heck, even 4GB should do the trick I suppose... Having ram in excess will not improve performance at all and you will never fill 32 gigs unless you do serious video editing.
Old December 23, 2012, 09:52 AM
Ahh I see. Ya do t want to get into that, don't think the games I play will require that. And plus with the equipment ill be getting (leaning more towards the second one I posted) think that should be good. Ahaha.. Yea I've had people tell me I don't need 32gb. I won't be doing any editing or running and software other than Microsoft word, power point and the games that I listed above.
Thanks suggestion/advice guys.
Keep em coming? :)
Old December 23, 2012, 11:56 AM
Well this is my pick. It's an Intel i5-3470 with 16GB of RAM and a Nvidia 660Ti video card. Motherboard is ASRock, which I never used before but seem to have decent reviews here. It's using the stock CPU cooler and doesn't have mouse and keyboard but it comes out to $1470 before tax and shipping.
*Edit: If you swap the case to something like a Corsair 200R, you save another $40 but it's a full size ATX case and not a smaller mATX case. Don't know if size is going to be an issue for you.
Intel Core i5-3470, EVGA GeForce GTX 660 Ti, Fractal Design Arc Mini - System Build - PCPartPicker
Old December 24, 2012, 09:47 AM
Thanks for the input guys think I'am going with this set up.
Old December 24, 2012, 12:56 PM
K I keep changing MY mind But here it iS?!?!
Intel Core i5-3570K, EVGA GeForce GTX 670, Corsair 500R Black - System Build - PCPartPicker
Old December 27, 2012, 05:14 AM
Again, don't go with the 3570K unless you are going to overclock. Save some money and go with an i5-3450. :-)
Got my new build to post, what's next? Mr. Toda New Builds 10 January 30, 2011 08:41 PM
First build ever (computer noob) Schnerf New Builds 24 July 30, 2009 03:47 PM
First Post - i7 Build keto New Builds 10 July 16, 2009 08:21 AM
Help a noob build a desktop for folding. Orkin New Builds 18 November 21, 2008 06:50 AM
First build - looking for suggestions (am noob) Nimbus CPU's and Motherboards 17 July 17, 2007 01:35 PM
