My first HTPC build ***EDIT*** = Check page 2 for my parts list please. Hello, I'm looking to build a new HTPC for my Panasonic TC-P55VT50. My details are below and any help would be GREATLY appreciated. What YOUR PC will be used for I will mainly use this PC to stream movies @ 1080p with proper surround sound to my TV and speakers respectively. I will also use this PC to surf the web and play music. I want the movies to play without any lag whatsoever and I want the PC to be fast, quiet and small. What YOUR budget is For my budget, I'm looking to spend roughly $800. I do have some spare parts laying around that I will try to use (such as an old PSU), but I'm not sure they work, so I have not listed them here. For the most part, let's try to get everything new (just in case). What country YOU will be buying YOUR parts from The best country in the World :p... Canada of course. IF YOU have a brand preference I prefer an Intel CPU. Other than that, I don't have any preferences. If there is good arguments for AMD, I'd go with that. If YOU intend on using any of YOUR current parts, and if so, what those parts are Let's say I need everything, including a nice wireless kb/mouse combo. IF YOU have searched and/or read similar threads I have read a few, but it seems those systems are about $1,000 - $1,500 and is that really necessary for an HTPC? IF YOU plan on overclocking or run the system at default speeds I do not plan to OC, since it is just my HTPC. WHEN do you plan to build it I plan to buy and build during the holidays. What resolution and settings do you use The PC must support 1080p without a hitch with 3D and proper surround sound. Are there any specific technologies you want - Fast - Quiet - SSD as the main drive - Bluray player - Support proper surround sound (Dolby, DTS, Etc...) - Support 1080p 3D Thank you in advance. Sorry if this is in the wrong section. |
Nvidia 3DTV doesn't support your TV so you won't get 3D support, so a cheap AMD APU system would be fine. |
3D HD Technology From Panasonic If it does not support that, I'd have to rethink things. Can you show me how you know it does not support nVidia 3D? |
Processor: i3 3220 $120 [i used to have phenom x2 560, and it would play bluray rips of 16 to 18gigs fine] motherboard: P8Z77-I DELUXE $180 or any1 from these Roundup: Eight Mini-ITX Mainboards for LGA1155 Processors - X-bit labs GPU: not needed i guess Sound Card: 7.1 Surround Sound Card around $80 [any1 from Asus/Creative][only if you are connecting speakers to your PC] RAM: Gskill Ripjawx 8GB $50 [4x2] Blu ray Player: LG BH10LS30 Blu-ray Drive $75 SSD: any Samsung/Corsair 240GB/120GB SSD $220/$130 respectively [can go for 60GB $90 as well, if you are not going to be installing any big softwares/games] Logitech Keyboard/Mouse Combo $40 Case: Am not good in this, so if any1 can fill in here PSU: 350W - 450W 80+ bronze/gold [if planning to do cable management, than a modular PSU, a little costly, will do the thing] Seasonic SS-350TGM 350W PFC 80PLUS Gold $75 am i missing anything? Prices are listed using amazon.com, tried to enter an average amount of the items Total goes to around $750[considering 120GB SSD], you can use the remaining $50 for the case I guess Ohh, and also, if you dont want to get a sound card, you can use the HDMI from the motherboard, and get the speaker output from the tv itself or for best quality, an AV receiver should give you a blasting entertainment |
The onboard video for the 3220 can't play 1080P. |
I've been trying to post a reply and it keeps saying something along the lines of "Your post will show up after an admin approves it" :( |
Dunno why everyone insists on ITX for HTPC's. I use a mATX since I have a 650Ti, and Auzen HometheaterHD Sound Card. ITX is just too small for me. |
My Lineup Case: Fractal Design Define Mini ~$100 CPU: Intel Core i3-3220 ~$130 Motherboard: MSI H77MA-G43 ~$85 Memory: Crucial Ballistix Sport 8GB ~$40 GPU: Gigabyte GTX 650 2GB ~$140 PSU: SeaSonic SSR-360GP 360W ~$60 ODD: Generic LG BluRay Reader ~$35 SSD: Crucial M4 128GB ~$110 HDD: Western Digital 1TB Green ~$80 Dunno if you need the HDD, 80 bucks buys a nice sound card GRAND TOTAL: $780 |
| All times are GMT -7. The time now is 11:37 PM. |
