-   -   Need second look for office computer build (http://www.hardwarecanucks.com/forum/new-builds/58509-need-second-look-office-computer-build.html)
bonanza2000 December 12, 2012 06:40 PM
1. What YOUR PC will be used for.
Office computer that I want to be stable, quick, and relevant for a long period of time
2. What YOUR budget is.
$1000
3. What country
USA - most likely newegg
4. IF YOU have a brand preference.
Higher quality parts and brands - Intel, Silverstone, Corsair, Coolermaster, G-Skill, etc
5. If YOU intend on using any of YOUR current parts
no
Yes, like smaller form factor computers
default settings and BIOS
soon - weeks
9. What resolution and settings do you use?
Normal settings
10. Are there any specific technologies you want?
USB 3.0 support, SSD (solid state drives), SATA3 6.0Gb/s.
Can't decide on Micro ATX versus Mini ITX. Seems like ITX is a bit more expensive, often the PSU comes with the case and maybe lower quality and maybe non-standard size, uses more expensive slimline DVD drive but is smaller. Micro ATX a bit bigger, can take normal PSU, a little cheaper build.
Thoughts and advice? Thanks in advance!
Micro ATX
CASE $80 SilverStone Sugo Series SG02B-F-USB3.0
CPU $145 Intel Core i3-3225 Ivy Bridge 3.3GHz LGA 1155
Display $145 Asus VE228H 21.5" Full HD HDMI LED BackLight LCD Monitor w/Speakers
DVD $20 LITE-ON 24X DVD Writer Internal Model IHAS324
MB $120 GIGABYTE GA-Z77M-D3H-MVP
OS $140 Microsoft Windows 7 Professional SP1 64-bit - OEM
PSU $99 COOLER MASTER Silent Pro M600
RAM $39 G.SKILL Ripjaws X Series 8GB (2 x 4GB) 1333 F3-10666CL9D-8GBXL
SSD $130 Intel 520 Series Cherryville SSDSC2CW120A310 2.5" 120GB SATA III
Keybd $18 Logitech MK120 Black USB Wired Slim Desktop
Total $936
mini ITX
CASE $130 SilverStone Sugo Series SG06B-USB3.0 Mini-ITX SFX 300W with 80 PLUS cert
DVD $110 HP Slim 12.7mm DVD-RW Optical Drive Black SATA Model 481043-B21
MB $130 GIGABYTE GA-Z77N-WIFI LGA HDMI SATA USB 3.0 Mini ITX
PSU $0 None
keybd $18 Logitech MK120 Black USB Wired Slim Desktop
other $11 StarTech SLSATAF20 Slimline SATA to SATA with LP4 Power Cable
Total $998
Masteroderus December 13, 2012 03:33 PM
Your i3 and z77 mobo are more expensive than the best amd apu on a decent gigabyte board.
Here is a a85 mobo from gigabyte :
Gigabyte F2A85XM-D3H w/ DDR3 1866, 7.1 Audio, Gigabit LAN, VGA, DVI-D, HDMI at Memory Express
Here is the a10 apu
AMD A10-5800K APU, Black Edition 3.8GHz w/ 4MB Cache at Memory Express
Total of 230 bucks Canadian. USB 3.0 and Sata III 6Gb and is micro ATX.
The plus side of owning a z77 mobo is being able to upgrade to an i5 or i7 in the future, which are great for productivity.
