Old August 27, 2013, 08:19 AM
"Quote This..."
Been there done that :)
Old January 22, 2014, 01:21 PM
mattydies's Avatar
Squeetard ~ Thanks for the pics. Someone had mentioned it.
That's an aluminum AC condenser right?
What do you do to avoid electrolysis / corrosion?
Old January 22, 2014, 01:26 PM
mattydies's Avatar
I'll spare you the details but I stayed with air for a while. Then I decided to try and mine some LITECoins (and maybe others as I read more). The cards arrived today (Ordered on the weekend). But I did not order the other parts I need yet (Not happy with myself on that one!)
YES I will be using the car radiator. Also this first timer realized if I set up the car rad in a certain way I no longer need a reservoir for my cooling system
After shelling out for a pair of Liquid cooled 290x's at their grossly inflated price I literally cannot afford to not get the water cooling ASAP! STAY TUNED FOLKS. It's finally happening!
EVGA Teases Upcoming X79 Dark Motherboard SKYMTL CPU's and Motherboards 18 January 11, 2013 04:16 PM
Hardwarecanucks should be renamed... Mark Off Topic 12 December 16, 2009 06:41 PM
nVIDIA: The Way It's Meant To Be Renamed ;) Silvgearx Press Releases & Tech News 10 June 23, 2009 10:58 PM
Dark Knight + EVGA X58 X3 SLI derrXIII CPU's and Motherboards 0 May 5, 2009 05:34 PM
Silent Hill V renamed 'Homecoming' Hardware Canucks Gaming 0 April 22, 2008 01:31 PM
