New Build - Need Input The system I am working on will be a Workstation/Gaming Rig (Basically a one size fits all type) I codenamed it "Overkill" Since it's exactly that. It's overkill, but I've never been one to go for good enough. Specs: Case: HAF 932 Full Tower MB: LGA 2011 ASUS Maximus V Extreme GPU: x2 680s CPU: 3930k (Decided not to do extreme edition for the simple fact there really isnt that much to gain for another 500 Dollars) RAM: 64 Gigs of G.Skill Ripjaws Storage: 512GB OCZ Vector SSD/ WD Red 2TB Drive Sound Card: ASUS Xonar Essence STX I'll add the peripherals later if requested. Anything you might want to add to this i'll take into consideration. |
Sound's cool. The LGA 2011 definitely is overkill lol. What have you estimated as total cost? Personally, I'd get another WD Red and mirror it so you don't have to worry about loosing your data. But that's just how I roll. Air or liquid? |
You gotta put that TVirus res in there ;) I'm using it for my build, but if you use a red one, that would be sweet, I'm surprised I haven't seen more builds use it. |
| All times are GMT -7. The time now is 07:26 AM. |
