Old December 9, 2012, 05:44 PM
Default First liquid cooled build!
1. What YOUR PC will be used for.
Gaming, some encoding/rendering, and school.
2. What YOUR budget is.
Probably around $400. I have everything except for a case, mobo, and fans for radiators. Already bought all the watercooling stuff which was an additional $200 ish.
Most likely Canada. Maybe some from America.
4. IF YOU have a brand preference.
Prefer Nvidia.
i7 2700k
intel 330 series
16gb ram
ax750
mcp655
rx360
rx240
microres
Looking to build a very nice TJ07 build if I can get my hands on one.
Quite experienced with overclocking. Will probably only do a light overclock to 4.0GH'z.
Planning to get all the parts by this Friday(14th), and start either the 14th or 15th.
9. What resolution and settings do you use?
Everything maxed, 8xaa 8xaf. 1080p 16:9
10. Are there any specific technologies you want?
No specific technologies needed. Just need ethernet, usb 2.0 at least, and pci-e 16x
I'm looking to build a custom tj07 build. What do you guys think? And do you have any tips for a custom midplate?
Thanks!
Old December 9, 2012, 06:15 PM
sswilson's Avatar
The only recomendation I'd make on the loop would be to consider a bay res to go with that 655. Not everybody will agree, but now that I've done two builds with bay res's I'll never look back.
Old December 10, 2012, 09:07 PM
I'll consider that after I get my hands on a TJ07, because I'm not sure if the bay res's will fit since I plan on doing a front mounted radiator which requires the removal of almost all the drive bays.
PNY Debuts Liquid Cooled Graphics at E3 Sam_Reynolds Press Releases & Tech News 8 June 11, 2011 08:26 PM
Asetek Liquid Cooled All-In-One PC Delivers True Desktop Performance FiXT Press Releases & Tech News 0 July 5, 2010 11:37 AM
BFG Announces Limited Edition Self Contained Liquid Cooled Graphics Cards FiXT Press Releases & Tech News 13 August 6, 2009 01:04 PM
My 1st build ever! Core i7, EVGA x58, Liquid cooled? Triggz New Builds 83 March 8, 2009 05:46 PM
Koolance Liquid Cooled 1200W Power Supply SKYMTL Reviews & Articles from the Web 3 May 21, 2007 10:53 PM
