Old November 12, 2012, 08:41 PM
Smile Harddisk Connectors... (Its a Bit Urgent)
Hey everyone....
Well a friend of mine is upgrading his system and he has a harddisk "seagate st3400 15a" which he likes to keep and he is going to buy a new power supply "Corsair Enthusiast Series™ TX650 V2" .. will this power supply be able to provide connection to that hard disk??? cuz his hard disk's connectors are some kind of pins.. and mine are some kind of l shaped connector???
Thanks... ^_^
Old November 12, 2012, 08:46 PM
Originally Posted by syaoran7li View Post
Hey everyone....
Thanks... ^_^
Yes won't be an issue.
Old November 12, 2012, 08:50 PM
It might work since molex connectors are still the norm but not IDE. If your friend's PC is new, not older than 5 years, his motherboard will most likely not have an IDE port. If his motherboard doesn't have an IDE port, get this.
Old November 12, 2012, 09:11 PM
They were asking about power not connector
Old November 12, 2012, 09:45 PM
Thanks for the reply guys... ^_^
ya i was asking about both power and the other connector... he is buying a new asus mother board "ASUS ASUS P8Z77-VLX"....
so it wont be a problem right??? or should i get a adapter or something like tat???
Old November 12, 2012, 10:11 PM
Upgrade that drive as that board doesn't have a ide connection
Old November 12, 2012, 10:23 PM
Ohhh okay.. Thanks for clearing my doubts... Thank you everyone... ^_^
Old November 12, 2012, 10:25 PM
Birk's Avatar
Yes, Enaberif is correct, Spend the extra ~$70-$120 and get a new much larger drive and just transfer the data over. That way you're not having to screw around with converters and worn out equipment getting in the way of performance.
Sli connectors (help and win?) clshades Troubleshooting 18 December 11, 2011 07:10 PM
[WTB] Urgent !!! Local Toronto - Need 2 -1/2in Barbs !!! Urgent mattlef Buy/Sell & Trade 0 April 3, 2011 04:44 PM
4 fans.. 2 3 pin connectors.. what do I do? irtehleet CPU's and Motherboards 5 May 12, 2010 08:28 AM
PWM Y Connectors impruv Air Cooling 0 January 25, 2010 08:16 AM
Power Connectors tim333 New Builds 4 April 9, 2009 09:56 AM
