-   -   new build please advice (http://www.hardwarecanucks.com/forum/new-builds/57761-new-build-please-advice.html)
CaRrReRa November 8, 2012 02:00 PM
hey, i want to build a pc but i need some advice i will be playing games and doing a little bit of video editing i choose the next
Core i7 3770K
Corsair H100
Asus P8Z77V-PRO
Corsair Vengeance 8GB
Crucial M4 256 GB (boot)
Seagate 2TB (storage)
Nvidia GTX680
Asus Xonar STX
Corsair 650D
Seasonic X760
what monitor do you recomend?
thx for the advice :)
summak November 8, 2012 03:11 PM
abt the monitor, what kind of gaming experience do you want to have??? There are 3 in general
1> 120/144FPS gaming
2> 3D Vision
3> Vivid Colors with 60fps
make your choice
ZZLEE November 8, 2012 03:28 PM
more RAM helps in coding.
faster ram leads to better overclocks.
CaRrReRa November 15, 2012 04:39 PM
2> 3D Vision
make your choice
the 3 i dont really like 3D
CaRrReRa November 15, 2012 04:40 PM
what do you suggest me?
bliz November 15, 2012 05:54 PM
You won't feel faster ram, it's like buying corsair platinum, it's just for blingbling and benching...What you get is wayyyyyy enough. and you can't bottleneck your PC with that ram^^
I recommend a 120hz screen ,but no 3D screen if you don't want,serously,it's stupid to have a GTX 680 and no 120hz screen! being limited to 60 FPS knowing that you get more than 100 in most games is not possible!!!!!
Soultribunal November 15, 2012 07:20 PM
Incorrect.
If you have a 680 and are driving a U3011 @2560x1600 you don't need 120hz since most of your GPU horsepower goes into rendering that resolution.
Please avoid using terms like 'stupid' in peoples build logs, as that is a detriment to a persons goals here and counter-productive.
-ST
bliz November 15, 2012 07:44 PM
Sorry,but i realized that the meaning of "stupid" is softer in french I didn't want to use a bad word or to say anything inapropriate, would traduce like "what a pity" or "dommage" in french,I didn't mean stupid,like "idiot",and "stupide" means both in french.I take my english grammar and i come back when i know it:haha:
Yep i forgot 2560x1600.Was thinking of 1080p, Forgot to mention that.That's stupid of me:blarg: .I knew that 2560x1600 destroys FPS.
Still, if you get 1080p,better get 120hz.Alse renember that you will need vsync, and in massive gaming epic moments, the FPS may not stay perfectly smooth because of the lock of 60 FPS.more than 60 is nicer.
