Old November 6, 2012, 12:46 PM
lootbag's Avatar
Default Opinions Please! X79 Watercooling Build.
Hellooo!
I have some questions about a new build I am putting together.
Will keep it brief for now and start off with a couple questions, since I am at work.
There is a budget in my mind... but it's not set in stone.
Quick run-down of main components:
- 3820/3930K (whatever I find a better deal on)
- Rampage IV Extreme
- GTX670 (680 PCB) SLI
- 32GB RAM THESE?
- Corsair AX750 (existing component and hopefully it will provide enough juice)
- Lian-li PC-A05NB (existing case I want to make use of)
Watercooling components:
- EK Supremacy CSQ Plexi/Copper CPU Block
- (2) EK FC680 GTX CSQ Plexi/Copper (but not 100% sure if I want to watercool the cards)
- (2) XSPC EX240 (good sizes for the case to keep the loop within the case)
- Koolance RP-452X2 Rev 2.0 or EK D5 X-RES 140 CSQ
- Dazmode D5 Vario
Major question on my mind right now is:
(because I am about to place an order)
Gigabyte GTX670 Windforce ($318.74) or EVGA GTX670 FTW ($359.99)?
- I know performance wise they are about the same, EVGA with the faster stock clock.
- I plan to pick up 2 of either one and run them without water until I can afford all the additional watercooling parts.
- I plan to use the RIVE motherboard so... I can't make up my mind if the darn blue pcbs on the gigabyte cards will bother me when they don't match the motherboard pcb (for when I go watercooling).
- Or should I wait till Black November sales start and hope for an even cheaper 670?
I will post more details about my plans for the waterloop later.
There are reasons for choosing specific reservoirs and radiators.
Please keep in mind it is my first time doing a custom open loop.
Will start a build log when components have arrived.
Thanks in advance for your opinions.
Old November 6, 2012, 01:06 PM
GT7R's Avatar
Get the EVGA cards since they use a reference 680 PCB in order to avoid incompatibility issues with waterblocks (the gigabite cards are non-ref and may be a pain to WC). Your choice of RAM is
Old November 6, 2012, 01:10 PM
lootbag's Avatar
Ahhh ok, so the gigabyte isn't the reference 680 PCB.
Thanks for clearing that up, I guess I know which cards to go for.
The RAM seems like a good deal
Old November 6, 2012, 01:45 PM
Your choice of hardware looks good!
I would definitely go with EVGA as they allow water cooling and they take great care of you if you need to RMA.
Old November 7, 2012, 12:11 PM
lootbag's Avatar
Another question I had in mind, will the (2) EX240s be enough radiator for an overclocked 3930K and two GTX670 FTW?
Old November 7, 2012, 01:53 PM
SugarJ's Avatar
Should be ok. I'd try to keep them on separate loops though.
Old November 8, 2012, 06:16 AM
lootbag's Avatar
Hmm, dual loops eh. Should be possible with the equipment I have listed. I will keep that in mind and do a little more research.
Old November 8, 2012, 07:18 AM
Liu Kang's Avatar
Dual loops = 2 pumps, 2 reservoirs, etc. A lot to fit in that case of yours.
480 worth of rad should be fine to cool those parts, and you can easily run pump>rads>cpu>gpu1>gpu2>reservoir>pump and get good results.
The key to a good WC build is the ease with which you can drain/fill your loop. Not an easy task with a bay reservoir. Consider a drain and fill line...
Good luck.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old November 14, 2012, 07:27 AM
lootbag's Avatar
So I ditched X79... because I bought a GA-Z77X-UP4 TH for $120 and picked up a 3770K.
Didn't "need" the extra memory capacity and graphics lanes.
Saved the extra cash for the watercooling setup and some pretty Dominator Platinums (8GBx2, DDR3-1600 and 9-9-9-24).
As a gift, I was also given a...
(*drum rolls*)
... Case Labs M8.
Always wanted a cube case and the significant other decided to be very generous.
And now of course the watercooling setup will change.
Good luck.
Liu Kang (or anyone with an answer), if I want to keep the Koolance bay reservoir and mount (2) 360 radiators on the bottom of the Case Labs M8, how do you think I should setup the drain ports?
I do not anticipate filling being a problem, the Koolance bay reservoir will be the highest point and is easy accessible for filling (front and top openings).
Should I buy 360 rads with more than two openings and use one of the extra ports for draining?
This seems like the easiest route.
Originally I just wanted to go with (2) RX360s.
Need opinions on new build! Bacchen New Builds 12 July 31, 2012 05:49 PM
Build Opinions icecoals New Builds 45 May 6, 2010 04:12 PM
Opinions of my first build? Munroe New Builds 2 November 5, 2009 08:35 PM
Opinions on build? MarX New Builds 7 August 28, 2008 04:00 PM
