<~----> Help! Looking for a miniITX build suggestion - Hardware Canucks
Old October 24, 2012, 10:08 PM
Default Help! Looking for a miniITX build suggestion
Hi folks,
I used to be more of a PC enthusiast, but I've been on the sidelines for probably 2-3 years without keeping up with the newest tech. My gaming PC is showing it's age, and is starting to become unstable, and I'd love to move to a physically smaller build to fit on my desk. This is what I'm moving from:
PhenomII x3 2.8ghz stock
Xigmatek Direct Heat Pipe something cooler
4gb DDR2 ram
Corsair M4 SSD 128GB/500GB HDD
Nvidia 470
Seasonic 650W PSU
CM690 case
I'd love to move to a mini (or micro?) ITX case, like the bitfenix prodigy. But I have no idea where to start.
From the sticky thread:
-Gaming at 1920x1080, don't need to max everything, but I do play shooters like BF3. I also do a decent amount of photo editing, lightroom can max out my current system pretty good.
I was hoping 5-600$ range, hoping to keep the GPU (nvidia 470) and maybe the PSU if it'll fit.
Canada (any sales or good buys right now would be appreciated ;)).
4. IF YOU have a brand preference.
No brand preference, but I would aim for an i5 quad core build. Power efficiency is nice on Intel's side, but not necessarily a deal breaker.
I was hoping to cannibalize my current build for the PSU, Xigmatek Direct Heat Pipe something cooler, SSDand keeping the GTX 470 GPU. Might upgrade to W8. So mostly looking for case, ram, mobo and CPU suggestions I suppose.
Read a little bit...most of the build's seem to be for full size cases and a bit out of my price range.
Novice overclocker..I don't mind tinkering around, but would be happy to run at stock. Stability is probably more important these days.
It's been on my radar for a bit. Currently have a working PC and no new games pushing me..but my current random instability is nagging. Probably don't want to wait until boxing day sales
9. What resolution and settings do you use?
1920*1080, generally play games on high settings. Might move up to a higher res 27" monitor but probably not viable to game on it.
10. Are there any specific technologies you want?
USB3? Dunno if theres any mobos with buildin wifi but that would be useful..
Thanks in advance!
Old October 25, 2012, 04:37 AM
I see soullessone21 has a itx board for sale
http://www.hardwarecanucks.com/forum...tml#post634444
some other threads of those that have gone before you:
High-end MITX Build
Mini ITX pc
M-ITX build suggestions
also the bitfenix prodigy case is 10 x 16 x 14 so while it is smaller than a tower case it isn't exactly tiny. If you want something that fits on a desk you could try the Sugo cases (SG05, SG06, SG07 and SG08). About the size of 3 reams of paper stack up. Down side is that you need a slim optical drive.
Newegg.com - Computer Hardware, Computer Cases, Mini-ITX Desktop, sugo
Old October 25, 2012, 12:41 PM
High-end MITX Build
Mini ITX pc
Thanks for the build ideas. I suppose the prodigy isn't tiny..I may look into the various Sugo cases. The naming and differences between the models isn't readily apparent, so I will have to look into what you get at those price points.
Completed MiniITX on Water [Q08+PA160] zoob Case Mods, Worklog & Gallery 32 January 9, 2012 07:43 PM
future build suggestion korreon New Builds 2 December 2, 2010 07:10 AM
Lan PC build suggestion upsidedown New Builds 0 November 11, 2010 12:52 PM
New Build need your reactions and suggestion :D CORE New Builds 3 April 21, 2009 06:56 PM
suggestion for a intel build ebdoradz CPU's and Motherboards 9 February 13, 2008 08:43 AM
