-   -   1400-1450 gaming pc, first build (http://www.hardwarecanucks.com/forum/new-builds/57469-1400-1450-gaming-pc-first-build.html)
computernoob29 October 23, 2012 11:37 AM
1. What YOUR PC will be used for. gaming, coding, maybe video editing
2. What YOUR budget is. $1400-$1450
canada, im buying from the ncix online store
4. IF YOU have a brand preference. intel cpu
no, i have a mac and an xbox 360
i will most definitely be overclocking the cpu and the gpu
3-4 weeks
9. sli or crossfire?
yes, next summer ill be getting 2 8970s or gtx 780s for three monitors
do you need a monitor? yes
do you need an operating system? yes
here is what i have put together:
case: nzxt phantom 410 white
motherboard: gigabyte z77 ud3h
cpu: intel i5 3570k
graphics card: msi power edition gtx 670
psu: xfx pro xxx 750w semi modular power supply
ssd: samsung 830 series 128gb ssdor ocz vertex 4, ill get whichever is closer to 100 bucks when i buy
ram: g.skill sniper 8gb 1600mhz ram
cpu cooler: cooler master hyper 212 evo
dvd drive: asus 24x dvd burner
monitor: asus vs228h-p 21.5 inch monitor
windows 7
thanks for your help in advance
great_big_abyss October 23, 2012 12:31 PM
Secondary harddisk?
or do you plan on only having 128GB total storage?
WD Caviar Black is always an excellent choice.
computernoob29 October 23, 2012 03:25 PM
next month ill get a hard drive, i would rather have 128gb of storage for a month and have a better graphics card then buy an ssd and a hdd and have to settle for a gtx 660ti or 7950
computernoob29 October 23, 2012 03:26 PM
other then that is it a good build? ive been obsessively researching the parts for it for the past month
Bond007 October 23, 2012 04:11 PM
Looks good. Personally I prefer a 23ish inch monitor, but that's a preference. Build and enjoy.
