Old November 21, 2012, 12:44 AM
December is fast approaching and I want to finalize my build..
I saw another dealer locally who sells wider variety of parts than the previous one..
Here's some of the changes I made from the build...
i just want to know if these parts are compatible..
(I also updated the 1st post)
Case: Antec Eleven Hundred --> Coolermaster HAF XM
Power Supply: FSP AURUM Series 80+ GOLD (600w) --> Corsair 750w TX750M 80PLUS Bronze (Modular)
MotherBoard: Asrock Z77 Extreme 4 --> ASUS P8Z77-V PRO
Processor: Intel Core i5 3570K 3.80 GHz
Cooler: CoolerMaster Hyper 212 EVO --> Corsair H100 Liquid CPU Cooler
GPU: Asus GTX670 DCII 2gb ddr5 256bit --> MSi GTX 670 2GB GDDR5 Power Up Edition
Memory: G.Skill RipJaws 8gb 1600 (12800CL9D) 2x4 --> Corsair Vengeance 8GB (2x4GB) DDR3 1600 CL9
HDD: 1.0TB Seagate Barracuda
SSD: 120gb Intel Sata3 SSD --> Corsair Force Series 3 120GB
Optical: ASUS 24X DVDwriter SATA DRW-24B5ST
and I have new Questions..
  • What do "Bronze, Gold and Platinum" mean on PSU? I'm actually confused when choosing the right PSU for I don't really know what I'm supposed to look for..
  • If I chose to do SLI configuration in future... will the 750w PSU be enough??
Old November 21, 2012, 01:19 AM
Bloodystumps's Avatar
The bronze , Gold , Platinum thing is a efficiency rating system you can read up on PSUs here and a 750 should be fine if in doubt check out the online calculator I think this is a more thorough one but I see that most manufacturers like Asus and Corsair have their own now ..
Old November 21, 2012, 01:49 AM
A 750W unit is sufficient. Not much reason to pay more for a motherboard unless you want the extra features that the Asus motherboard provides. The RAM change is unnecessary. You're not gaining much other than aesthetics. I would go with an Intel SSD over a Corsair one. Not to say that Corsair is bad, both are almost equally good but Intel wins by a bit. I'm using Corsair Force GT, no problems with it.
First PC build, open for suggestions. KillaByte New Builds 5 August 20, 2012 10:57 AM
A new gaming rig, needs some suggestions kaupol New Builds 5 October 15, 2011 04:24 PM
Gaming laptop suggestions..... sswilson Mobile Computing 40 April 24, 2011 02:08 PM
Suggestions for gaming PC joshcUK New Builds 28 March 22, 2011 12:58 AM
open air case suggestions gingerbee Cases 5 March 28, 2009 05:57 AM
