Old October 10, 2012, 09:15 AM
Shadowmeph's Avatar
Default which micro or mini motherboard for OCing 2500K cpu
I finally broke down and bought a Intel 2500k which I want to OC but I don't want to spend to much on a Motherboard which motherboard s are good for OCing this cpu and should I buy new ram I am fairly new to overclocking and this 1100T only stably ocs to 3.9? like I mentioned I plan on OCing this and then if I see and noticed enough improvement for everyday use and gaming over my 1100 amd then I will switch this out .
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old October 10, 2012, 09:27 AM
great_big_abyss's Avatar
And you want to go mITX? Or mATX?
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old October 10, 2012, 10:22 AM
Shadowmeph's Avatar
actually it doesn't matter just as long as it is a decent board for OCing , I just don't need a board that has more then one vid card slot
Folder :
Old October 10, 2012, 10:28 AM
dandelioneater's Avatar
I would avoid m-itx if overclocking is your main goal. Those boards don't overclock as nicely as a regular boards will - BIOS features are pretty sparse like no load line calibration control. A regular ATX 1155 board will probably be cheapest.
Old October 10, 2012, 10:42 AM
Shadowmeph's Avatar
ok do you have any recommendations?
Folder :
Old October 10, 2012, 10:49 AM
EVGA Z68 SLI ATX Z68 LGA1155 DDR3 3PCI-E16 3PCI-E1 USB3.0 Sandy Bridge Motherboard $120
ASUS P8Z77-M mATX LGA1155 Z77 DDR3 2PCI-E16 1PCI-E1 1PCI SATA3 HDMI DVI USB3.0 MotherboardMSI Z77A-GD55 ATX LGA1155 Z77 DDR3 3PCI-E16 4PCI-E1 SATA3 DVI HDMI VGA DX11 USB3.0 Motherboard $115
Something like these would be ok i think.
Old October 10, 2012, 12:00 PM
ASUS P8Z77-I Deluxe mITX Peformance Gaming Motherboard Unboxing & FIrst Look Linus Tech Tips - YouTube
exactly what you need,no? It's not a very expensive board, and awesome for OC
Old October 12, 2012, 10:20 AM
that's a bit expensive bliz, I don't think he will take it. But the other Asus, the micro atx one would be nice
Get OCing motherboard for 2500K or spend on GPU? frontier204 CPU's and Motherboards 12 October 6, 2012 09:34 AM
Mini itx or micro atx build chel- New Builds 7 May 5, 2012 11:56 AM
trying to get the most out of GTA4 with i5-2500K OCing TedShackley CPU's and Motherboards 3 January 25, 2012 07:50 AM
Micro-atx motherboard Rigs64 HTPC Systems & Software 10 April 26, 2009 10:30 PM
2x2 GB Crucial & 2 GB Buffalo value RAM OCing mini-review -n7- Member Reviews 6 May 19, 2008 08:40 PM
