Old October 4, 2012, 10:44 AM
great_big_abyss's Avatar
Originally Posted by igot6strings View Post
Pop a 7750 in there and it'll be a sweet gaming rig. It'll even handle some of the newer games on med-high settings. OCs quite well too.
This defeats the point of going with an APU. He'll have more than enough horsepower for the games his neice and nephew want to play. No need to up the cost with a discrete GPU.
Old October 4, 2012, 02:06 PM
Possibly, but you can add the card for dual graphics mode or am I out to lunch? I don't know much about this platform to be honest.
Old October 4, 2012, 02:13 PM
I believe it is possible to crossfire with certain cards but as GBA said, it is way overkill for the system in mind and kind of defeats the purpose of going with an APU otherwise I gotta say I would go intel. :)
Maybe in a couple years down the road once the machine starts to lose it's firepower the chip can be overclocked and a discrete card added for moar powa!
Old October 4, 2012, 02:41 PM
EagerBeaver's Avatar
May I suggest the SilverStone Temjin TJ08-E for the case? They are $100 but you can easily get one for under $100 with an NCIX price match. I'm downsizing my current rig and that is the case I'm going for. It's an awesome and tough case!
Old October 4, 2012, 02:46 PM
I like it because you can put an mATX board in it (reducing cost vs. mITX) and you can also fit a conventional cooler such as a Coolermaster Hyper 212+.
Thank You! I may end up going for this case, too, for my stepson's AMD APU build.
Old October 4, 2012, 02:58 PM
It's a beautiful case, and the reason I'm downsizing is to save money!
Also check out the Silverstone PS07, I was looking at it also. They seem the same the same interior wise, but differ on the exterior. Perfect since you have to build two setups, because sibling don't like having the same stuff. They can have the same rig internally, but externally they'll look different and can tell their rigs apart. Good luck with your build, I'm all about M-ATX builds now!
Old October 4, 2012, 05:07 PM
I doubt you would need that SSD. Personally I would pick up a nice 1tb drive for around 70$ if you check the ncix sale.
Old October 4, 2012, 05:36 PM
Bond007's Avatar
With their uses I would either vote for A8/A10, or a pentium CPU and hd6670.
  #19 (permalink)
Old October 5, 2012, 05:20 AM
I have several office computers with the Silverstone SG06 case. Remember you have to get a slimline drive DVD and the appropriate cable. If you get a 2.5" hard drive you can eliminate the 3.5" hard drive cage which hangs below the DVD bay and gives you more room. I used the stock CPU cooler for the i3 chip with no graphics card running the machines as plain jane office machines that run MS office and other software and never see temps higher than low 40s C temps. They are cute little cases and don't take up a lot of space (maybe 3 reams of paper stacked up).
  #20 (permalink)
Old October 5, 2012, 08:28 PM
Depending on your budget you should definitely go with the A10.
Light To Moderate Gaming and Entertainment Build. $750 Budget geokilla New Builds 4 August 13, 2012 10:30 PM
HD 6310M for light gaming? dimre01 Mobile Computing 7 July 30, 2011 12:58 PM
[WTB] GPU for light gaming kanadien Buy/Sell & Trade 2 March 29, 2011 10:08 AM
Modest AMD Build fjanicki New Builds 14 August 18, 2010 10:51 PM
Gaming with Light editing work. Phenom II build? manbearpig New Builds 3 January 22, 2009 07:47 AM
