Old September 24, 2012, 05:52 PM
Bond007's Avatar
I would also go with a 670. 480 are too noisy and power hungry IMO. Otherwise the build looks good. Congrats and enjoy.
Old September 24, 2012, 08:13 PM
The 480, or-- as I liked to call it when I had it-- "the abomination," is quite an unfortunate creation of a card with its immense power draw and consequent noise. Since you're watercooling and have already bought a 1000w PSU, the criticisms against it are more or less mitigated in your case, but for any other standard build, it is VERY hard to recommend the card.
So, in my opinion, it really just comes down to budget. Is selling the 480 to put toward a 670 not too much of a loss vs. adding another 480? Then I would suggest it. If it is too much of a loss/hassle, then SLI those mofos, and everyone else's opinion be damned.
(I'm kinda curious what your power bill would be like though...)
Old September 24, 2012, 08:23 PM
Hmm... yea, I can drop the power draw and heat to some extent. But then what's the point of the SLI right? I can probably sell the 480 for ~ 150 if I get lucky. I can buy one for ~215 shipped taxes in. Total expense would be.. 360.. NCIX has gtx 670s on for 349.99+tax and shipping. Total cost would be around 423 (30 dollar MiB on 379.99). The cost difference isn't all that much. You have me thinking.
i7 3770k or i5 3570k netgears CPU's and Motherboards 9 July 9, 2012 09:58 AM
Help with 3570K OC uberness Overclocking, Tweaking and Benchmarking 3 July 8, 2012 04:45 AM
3570k super hot? jiepo Overclocking, Tweaking and Benchmarking 25 July 5, 2012 06:02 PM
First budget gaming build (2500k VS. 3570K) Chuck390 New Builds 58 May 9, 2012 06:36 AM
Help choosing a MB for i5 3570K? Lucasrivers CPU's and Motherboards 2 April 30, 2012 03:18 PM
