Old September 22, 2012, 05:37 PM
Default memory problem?
I build myself a new computer! Yay!
But The memory isn't running according to the box :/
CL9-9-9-24 1.5V 1600mhz.
it's running the voltages right. but the frequency aint right :[ it's 1333
I'm not too sure about the timing either. It shoes a lot of numbers in the bios, it's so confusing!
Btw the ram kit is F3 12800CL9D-8GBXL. G.Skill. 4096x2mB.
and also, the motherboard is ga-b75m-d3h
How do i make it run into 1600mhz? :[ the only thing i see in the bios is Memory Multiplier. Idk if that helps... I heard that there should be XMP or something called like that. But I dont see it in the Bios :[
Thanks for the quick replies!
Old September 22, 2012, 05:50 PM
sswilson's Avatar
If you're running stock then the memory multi is exactly the setting you need to bump up. Just ensure that the voltage is set correctly first.
edit: As far as the mem settings are concerned, you'll have to set those as well.
Old September 22, 2012, 05:58 PM
Default :/
It's running at 1333mhz with 1.5v :[
It should be 1600mhz with 1.5v.
How much am i suppose to bump the mulitplier for me to get 1600mhz?
EDIT: On my computer it says 8GB. But ( 7.66 Usable? ) I have 64bit. Why?
Old September 22, 2012, 06:42 PM
sswilson's Avatar
Always go one bump at a time in order to allow auto for your secondary memory settings to find stability.
Before you make any changes though, do yourself a favour and download a program called cpu-z in order to see what your current settings are, and then work from there.
Old September 22, 2012, 07:02 PM
one bump at the time?
Old September 22, 2012, 07:07 PM
sswilson's Avatar
I don't know your motherboard bios settings, I don't know your processor, I don't know your proc's bus speed, so it's hard to be any more specific.
Whatever the memory multiplier is currently set to, bump it up one higher and then check cpu-z to see what settings it's running at.
Old September 22, 2012, 07:11 PM
MOtherbaord : GA-B75M-D3H
Processor : I3 2120.
Bus speed is ..ehh 100? Multipler is 33.
Memory Multiplier is set to 13.3 right now.
EDIT : CPU-z it's written : 9-9-9-24 but the DRAM part was 666 or something simular. but not 800.
Old September 22, 2012, 07:38 PM
You need to keep upping the memory multiplier until your freq reaches 1600, on that motherboard it will show you both the stock freq and the freq that is adjusted by changing the multiplier.
Old September 22, 2012, 07:44 PM
It won't let me. the highest is 13.3 for some reason.
I can go lower though. 8 For 800mhz frequency
10.66 for 1066mhz :[
Edit : idk if this will help but
CAS latency 11
TRCD:11
tRP:11
tRAS:28
but oddly on cpu-z it's 9-9-9-24 :[
memory or mobo problem kanganova Troubleshooting 8 January 26, 2010 04:17 PM
p5q-e + patriot memory problem Finch RAM 74 November 13, 2008 04:05 PM
xfx 680i memory problem t0m Troubleshooting 49 March 21, 2008 02:19 PM
Memory problem with new build francois methot CPU's and Motherboards 10 July 23, 2007 09:50 AM
...is it a memory problem? francois methot Overclocking, Tweaking and Benchmarking 9 March 23, 2007 11:33 PM
