Old August 31, 2012, 10:16 AM
is it ok if i used my old asus gtx560 directcu for this build?would it bottleneck the performance?
Old August 31, 2012, 06:26 PM
Dzzope's Avatar
Yes and Yes.. it will run games reasonably well at 1920x1080 but it will be the limiting factor in your rig.. a 660ti will be about twice as fast and offer a much better experience (in games that need really good cards)
You can use it as a stop-gap though and then bump the GPU in a few months.. the rest of the build should be good for minimum 3 usually 5 possibly up to 7 years depending on your needs and what technology does in the mean time.
I would generally advise a 660ti base for this kind of a sytem but if you have a 560 and can't afford the bigger card yet then as said it will do as a stop-gap.
If the 560 is all the performance you need then the rest of the machine is probably over-powered but will last longer than a cheaper build.
Old August 31, 2012, 11:31 PM
Thanks dude,that really good idea.I appreciate ur thought.
Old September 2, 2012, 10:45 AM
MARSTG's Avatar
by mentioning Leadtek we take it you are not in North America?
Old September 6, 2012, 08:21 AM
Yes I from Malaysia.
I'm trying to decide between the MBP 13 and the MBA 13 x30Jx Mac 13 August 10, 2012 10:25 AM
Can't decide martin_metal_88 Air Cooling 1 February 28, 2010 01:20 PM
i7 or PH2 (help me decide) trayton New Builds 6 October 21, 2009 01:01 PM
help me decide bcguy Audio 5 July 14, 2009 10:32 PM
Can't Decide bumfloss Video Cards 10 April 30, 2009 04:49 AM
